139 Personne(s) en ligne (91 Personne(s) connectée(s) sur Forum)
Invité(s): 139
Lecteur de code defaut OBD II
De A coté de Lille
Post(s): 8
Bonjour pour dépanner que pensez de ce boitier????
http://www.norauto.fr/Acheter-Lecteur ... SI-/6.html#div_descriptif
Contribution le : 13/08/2013 09:59
Re: Lecteur de code defaut OBD II
si jamais sa fonctionne sa coûte beaucoup moins cher sur le net
Contribution le : 13/08/2013 17:30
0.000112 - SET NAMES 'utf8'
0.000160 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001018 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '16e68482deac9ff667d2dd5e390a50ce'
0.000567 - SELECT * FROM bb_topics WHERE topic_id=18021
0.000067 - SELECT * FROM bb_forums WHERE forum_id = 35
0.000724 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '35' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000528 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 18021
0.000058 - SELECT * FROM bb_topics WHERE topic_id=18021
0.000180 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=18021 AND approved = 1
0.000622 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=18021 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000679 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =18021
0.000390 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000608 - UPDATE online SET online_updated=1793910092, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000297 - SELECT * FROM online
0.000228 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000471 - UPDATE online SET online_updated=1793910092, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000964 - UPDATE bb_online SET online_updated= '1793910092', online_forum = '35', online_topic = '18021' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000208 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001094 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','8.243.72.189','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','116.96.78.115','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','31.105.111.80','191.81.63.237','41.182.143.40','109.242.90.144','169.224.0.30','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','45.65.167.138','109.245.151.204','38.74.245.120','109.196.67.205','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','186.91.18.171','106.73.159.193','41.83.45.142','212.93.153.39','188.151.133.137','185.191.171.11','109.81.12.155','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','38.252.48.48','190.145.240.183','14.231.252.236','185.191.171.13','202.46.62.80','85.208.96.209','216.73.216.244','173.33.114.42','200.180.238.253','177.70.165.214','85.208.96.193','85.217.249.150','152.249.11.244','45.148.232.205','90.14.5.65','93.117.164.200','213.232.122.23','177.10.219.114','185.244.154.87','40.77.167.235','66.249.70.192','138.84.47.240','134.249.12.43','201.180.185.250','191.108.51.228','87.83.122.151','40.77.167.121','2.215.146.133','185.191.171.18') )
0.000200 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '18021'
0.000243 - SELECT * FROM bb_online WHERE (online_topic = '18021' AND online_uid <> '0')
0.000048 - select forum_name from bb_forums WHERE forum_id=29
0.000287 - SELECT * FROM `users` WHERE uid IN (9233,1315)
0.000157 - SELECT * FROM bb_online WHERE online_uid IN (9233,1315)
0.000181 - SELECT groupid FROM groups_users_link WHERE uid=9233
0.000084 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8 AND rank_max >= 8 AND rank_special = 0
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000170 - SELECT post_id FROM bb_posts WHERE topic_id = 18021 AND pid = 0
Total: 49
Usage de la mémoire: 8144096 bytes
XOOPS a mis 0.124 seconde(s) pour charger
