Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (44) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000132 - SET NAMES 'utf8'
0.000261 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'a7117a5eb0c16c3a4ef943e3aa8cdf51'
0.000176 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000288 - SELECT COUNT(*) FROM protector_access WHERE ip='3.235.45.196' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=10297'
0.000169 - SELECT COUNT(*) FROM protector_access WHERE ip='3.235.45.196'
0.000231 - INSERT INTO protector_access SET ip='3.235.45.196',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=10297',expire=UNIX_TIMESTAMP()+'60'
0.000452 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 10297
0.000197 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000060 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000058 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001604 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000397 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 491
0.000161 - SELECT * FROM bb_topics WHERE topic_id=491
0.000244 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=491 AND approved = 1
0.000225 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=491 AND approved = 1 AND post_id < 10297
0.000356 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=491 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000210 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =491
0.000061 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000048 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000135 - SELECT * FROM groups
0.000096 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000306 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000205 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1597246259, '3.235.45.196', 5)
0.000306 - SELECT * FROM online
0.000242 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000229 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000256 - UPDATE online SET online_updated=1597246259, online_module = 5 WHERE online_uid = 0 AND online_ip='3.235.45.196'
0.000204 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000130 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1597246259, '3.235.45.196', 6, 491)
0.000419 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000408 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('3.235.45.196','46.229.168.132','114.119.167.169','114.119.166.165','114.119.166.244','207.46.13.84','40.77.189.51','216.244.66.230','157.55.39.113','89.237.74.142','114.119.165.26','63.143.42.253','207.46.13.51','157.55.39.71','66.249.70.22') )
0.000134 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '491'
0.000230 - SELECT * FROM bb_online WHERE (online_topic = '491' AND online_uid <> '0')
0.000407 - SELECT * FROM `users` WHERE uid IN (273,5,90,1,230,41)
0.000182 - SELECT * FROM bb_online WHERE online_uid IN (273,5,90,1,230,41)
0.000145 - SELECT groupid FROM groups_users_link WHERE uid=273
0.000173 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 686 AND rank_max >= 686 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7247928 bytes
XOOPS a mis 0.084 seconde(s) pour charger
Module display a mis 0.008 seconde(s) pour charger
