Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (45) Requête(s) (51) Bloc(s) (5) Extra (2) Temporisation(5)
0.000135 - SET NAMES 'utf8'
0.000054 - SET SQL_BIG_SELECTS = 1
0.000313 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '9bb5881c31f0b1a712fc6e00df3bcd12'
0.000119 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000119 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000296 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000202 - SELECT COUNT(*) FROM protector_access WHERE ip='3.235.45.196' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=14596'
0.000168 - SELECT COUNT(*) FROM protector_access WHERE ip='3.235.45.196'
0.000217 - INSERT INTO protector_access SET ip='3.235.45.196',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=14596',expire=UNIX_TIMESTAMP()+'60'
0.000486 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 14596
0.000069 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000083 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001599 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000385 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 1022
0.000221 - SELECT * FROM bb_topics WHERE topic_id=1022
0.000326 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=1022 AND approved = 1
0.000276 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=1022 AND approved = 1 AND post_id < 14596
0.000612 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=1022 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000378 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =1022
0.000097 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000060 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000117 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000123 - SELECT * FROM groups
0.000110 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000066 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000331 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000241 - UPDATE online SET online_updated=1597247316, online_module = 5 WHERE online_uid = 0 AND online_ip='3.235.45.196'
0.000157 - SELECT * FROM online
0.000144 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000056 - -300
0.000254 - DELETE FROM online WHERE online_updated < 1597247016
0.000192 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000195 - UPDATE online SET online_updated=1597247316, online_module = 5 WHERE online_uid = 0 AND online_ip='3.235.45.196'
0.000186 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.235.45.196'
0.000198 - UPDATE bb_online SET online_updated= '1597247316', online_forum = '6', online_topic = '1022' WHERE online_uid = 0 AND online_ip='3.235.45.196'
0.000180 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000345 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('46.166.182.33','3.235.45.196','114.119.164.173','114.119.167.169','114.119.166.190','114.119.163.218','66.249.70.24','23.102.174.254','114.119.164.234','66.249.64.46','185.25.35.8','63.143.42.253','40.77.167.166','114.119.160.139') )
0.000159 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '1022'
0.000149 - SELECT * FROM bb_online WHERE (online_topic = '1022' AND online_uid <> '0')
0.000387 - SELECT * FROM `users` WHERE uid IN (348,1,41)
0.000159 - SELECT * FROM bb_online WHERE online_uid IN (348,1,41)
0.000168 - SELECT groupid FROM groups_users_link WHERE uid=348
0.000201 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 818 AND rank_max >= 818 AND rank_special = 0
0.000132 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000136 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 7
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7174944 bytes
XOOPS a mis 0.097 seconde(s) pour charger
Module display a mis 0.011 seconde(s) pour charger
