Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (67) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000149 - SET NAMES 'utf8'
0.000108 - SET SQL_BIG_SELECTS = 1
0.000198 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0f746871b0852f9414905d72cf68fa25'
0.000265 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000195 - SELECT COUNT(*) FROM protector_access WHERE ip='3.231.220.225' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=180078'
0.000136 - SELECT COUNT(*) FROM protector_access WHERE ip='3.231.220.225'
0.000129 - INSERT INTO protector_access SET ip='3.231.220.225',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=180078',expire=UNIX_TIMESTAMP()+'60'
0.000209 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 180078
0.000140 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000992 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000190 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9918
0.000108 - SELECT * FROM bb_topics WHERE topic_id=9918
0.006889 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9918 AND approved = 1
0.000209 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9918 AND approved = 1 AND post_id < 180078
0.000595 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9918 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000205 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9918
0.000048 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000132 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000046 - SELECT * FROM groups
0.000092 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000095 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000216 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.231.220.225'
0.000225 - UPDATE online SET online_updated=1591311394, online_module = 5 WHERE online_uid = 0 AND online_ip='3.231.220.225'
0.000206 - SELECT * FROM online
0.000161 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000189 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.231.220.225'
0.000211 - UPDATE online SET online_updated=1591311394, online_module = 5 WHERE online_uid = 0 AND online_ip='3.231.220.225'
0.000264 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.231.220.225'
0.000131 - UPDATE bb_online SET online_updated= '1591311394', online_forum = '3', online_topic = '9918' WHERE online_uid = 0 AND online_ip='3.231.220.225'
0.000131 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000142 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('3.231.220.225','114.119.167.169','54.36.149.21','114.119.166.244','46.229.168.135','54.36.148.10','46.229.168.146','54.36.148.61','144.76.23.209') )
0.000099 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9918'
0.000115 - SELECT * FROM bb_online WHERE (online_topic = '9918' AND online_uid <> '0')
0.000847 - SELECT * FROM `users` WHERE uid IN (21,1,5,103,1315,2683,3379,1038,992,2633,2759,3026,888,2140,1885,2655,3408,3153,3050,1686,2566,1132,1273)
0.000227 - SELECT * FROM bb_online WHERE online_uid IN (21,1,5,103,1315,2683,3379,1038,992,2633,2759,3026,888,2140,1885,2655,3408,3153,3050,1686,2566,1132,1273)
0.000169 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000293 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 8623664 bytes
XOOPS a mis 0.080 seconde(s) pour charger
XOOPS output init a mis 0.029 seconde(s) pour charger
Module display a mis 0.008 seconde(s) pour charger
