Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (67) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000111 - SET NAMES 'utf8'
0.000169 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'a68177d0148e02d260d7f133e69d3b8f'
0.000138 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000159 - SELECT COUNT(*) FROM protector_access WHERE ip='3.236.108.61' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=180120'
0.000118 - SELECT COUNT(*) FROM protector_access WHERE ip='3.236.108.61'
0.000157 - INSERT INTO protector_access SET ip='3.236.108.61',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=180120',expire=UNIX_TIMESTAMP()+'60'
0.000230 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 180120
0.000054 - SELECT * FROM bb_forums WHERE forum_id = 3
0.000042 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '3' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000217 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9918
0.000145 - SELECT * FROM bb_topics WHERE topic_id=9918
0.000438 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9918 AND approved = 1
0.000231 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9918 AND approved = 1 AND post_id < 180120
0.000644 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9918 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000248 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9918
0.000383 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.236.108.61'
0.000277 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1593677520, '3.236.108.61', 5)
0.000146 - SELECT * FROM online
0.000149 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.236.108.61'
0.000130 - UPDATE online SET online_updated=1593677520, online_module = 5 WHERE online_uid = 0 AND online_ip='3.236.108.61'
0.000161 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.236.108.61'
0.000112 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1593677520, '3.236.108.61', 3, 9918)
0.000153 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000205 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.166.165','23.99.97.96','185.25.35.13','40.77.167.217','3.236.108.61','114.119.163.218','144.76.23.207','40.77.167.178','114.119.166.244','114.119.164.173','86.250.142.179','114.119.165.26','207.46.13.173','17.58.97.78','114.119.167.117') )
0.000105 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9918'
0.000150 - SELECT * FROM bb_online WHERE (online_topic = '9918' AND online_uid <> '0')
0.000953 - SELECT * FROM `users` WHERE uid IN (21,1,5,103,1315,2683,3379,1038,992,2633,2759,3026,888,2140,1885,2655,3408,3153,3050,1686,2566,1132,1273)
0.000239 - SELECT * FROM bb_online WHERE online_uid IN (21,1,5,103,1315,2683,3379,1038,992,2633,2759,3026,888,2140,1885,2655,3408,3153,3050,1686,2566,1132,1273)
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 8625208 bytes
XOOPS a mis 0.079 seconde(s) pour charger
Module display a mis 0.009 seconde(s) pour charger
