Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (55) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000166 - SET NAMES 'utf8'
0.000089 - SET SQL_BIG_SELECTS = 1
0.000307 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '6f1e8c7dad12302c58fab26497b99da0'
0.000092 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000194 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000335 - SELECT COUNT(*) FROM protector_access WHERE ip='3.228.220.31' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=2527'
0.000190 - SELECT COUNT(*) FROM protector_access WHERE ip='3.228.220.31'
0.000266 - INSERT INTO protector_access SET ip='3.228.220.31',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=2527',expire=UNIX_TIMESTAMP()+'60'
0.000400 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 2527
0.000068 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000061 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000081 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000075 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000328 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 193
0.000161 - SELECT * FROM bb_topics WHERE topic_id=193
0.000408 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1
0.000236 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1 AND post_id < 2527
0.000791 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=193 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000449 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =193
0.000061 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000106 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000057 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000102 - SELECT * FROM groups
0.000063 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000454 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.228.220.31'
0.000494 - UPDATE online SET online_updated=1596562069, online_module = 5 WHERE online_uid = 0 AND online_ip='3.228.220.31'
0.000173 - SELECT * FROM online
0.000221 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.228.220.31'
0.000176 - UPDATE online SET online_updated=1596562069, online_module = 5 WHERE online_uid = 0 AND online_ip='3.228.220.31'
0.000203 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.228.220.31'
0.000335 - UPDATE bb_online SET online_updated= '1596562069', online_forum = '6', online_topic = '193' WHERE online_uid = 0 AND online_ip='3.228.220.31'
0.000349 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('207.46.13.135','114.119.166.190','3.228.220.31','114.119.165.26','40.77.167.73','157.55.39.186','114.119.167.117','207.46.13.167','114.119.167.169','207.46.13.17','114.119.160.139','114.119.166.165','157.55.39.144','40.77.167.123','40.77.167.58','114.119.166.244','114.119.164.173','40.77.167.151','63.143.42.253') )
0.000146 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '193'
0.000221 - SELECT * FROM bb_online WHERE (online_topic = '193' AND online_uid <> '0')
0.000653 - SELECT * FROM `users` WHERE uid IN (72,41,5,83,1,82,13,9,21)
0.000271 - SELECT * FROM bb_online WHERE online_uid IN (72,41,5,83,1,82,13,9,21)
0.000214 - SELECT groupid FROM groups_users_link WHERE uid=72
0.000240 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 804 AND rank_max >= 804 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7695736 bytes
XOOPS a mis 0.082 seconde(s) pour charger
Module display a mis 0.009 seconde(s) pour charger
