Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (55) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000214 - SET NAMES 'utf8'
0.000082 - SET SQL_BIG_SELECTS = 1
0.000212 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7e1e02ef5906649a717d3971be33691e'
0.000092 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000217 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000237 - SELECT COUNT(*) FROM protector_access WHERE ip='18.204.55.168' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=2680'
0.000215 - SELECT COUNT(*) FROM protector_access WHERE ip='18.204.55.168'
0.000309 - INSERT INTO protector_access SET ip='18.204.55.168',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=2680',expire=UNIX_TIMESTAMP()+'60'
0.000335 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 2680
0.000157 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001205 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000259 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 193
0.000185 - SELECT * FROM bb_topics WHERE topic_id=193
0.000347 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1
0.000221 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1 AND post_id < 2680
0.000597 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=193 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000379 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =193
0.000112 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000092 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000100 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000136 - SELECT * FROM groups
0.000140 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000069 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000406 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.204.55.168'
0.000339 - UPDATE online SET online_updated=1597163134, online_module = 5 WHERE online_uid = 0 AND online_ip='18.204.55.168'
0.000178 - SELECT * FROM online
0.000264 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.204.55.168'
0.000168 - UPDATE online SET online_updated=1597163134, online_module = 5 WHERE online_uid = 0 AND online_ip='18.204.55.168'
0.000231 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.204.55.168'
0.000238 - UPDATE bb_online SET online_updated= '1597163134', online_forum = '6', online_topic = '193' WHERE online_uid = 0 AND online_ip='18.204.55.168'
0.000262 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000361 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.70.20','207.46.13.54','207.46.13.47','185.25.35.14','114.119.165.26','18.204.55.168','63.143.42.253','207.46.13.105','157.55.39.222','114.119.167.117','114.119.166.244','114.119.167.169','66.249.70.24','114.119.163.218','40.77.167.68','185.25.35.9','207.46.13.159','114.119.164.234') )
0.000165 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '193'
0.000187 - SELECT * FROM bb_online WHERE (online_topic = '193' AND online_uid <> '0')
0.000638 - SELECT * FROM `users` WHERE uid IN (72,41,5,83,1,82,13,9,21)
0.000259 - SELECT * FROM bb_online WHERE online_uid IN (72,41,5,83,1,82,13,9,21)
0.000222 - SELECT groupid FROM groups_users_link WHERE uid=72
0.000272 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 804 AND rank_max >= 804 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7696032 bytes
XOOPS a mis 0.110 seconde(s) pour charger
XOOPS Boot a mis 0.027 seconde(s) pour charger
Module init a mis 0.032 seconde(s) pour charger
Module display a mis 0.011 seconde(s) pour charger
