83 Personne(s) en ligne (67 Personne(s) connectée(s) sur Forum)
Invité(s): 83
tableau de bord lisse
Post(s): 6
bsr a tous voila j'aimerai eventuellement oter le simili gris fonce du haut de tableau de bord pour le lisser. mais qu'y a t'il dessous? si qq a deja demonte ou si ca se vend en fibre...
merci d'avance.
par la meme occasion meme question pour les panneaux de porte avant
Contribution le : 29/04/2011 19:29
Re: tableau de bord lisse
Quelqu'un a déjà fait cela ... Fais une recherche...
Contribution le : 30/04/2011 08:32
Contribution le : 30/04/2011 11:38
0.000081 - SET NAMES 'utf8'
0.000543 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002949 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '2a08eaf6f42228dfdaedd4d2a7953f54'
0.000277 - SELECT * FROM modules WHERE dirname = 'newbb'
0.001918 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000545 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000211 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 284547
0.000131 - SELECT * FROM bb_forums WHERE forum_id = 6
0.001166 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001007 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001045 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000177 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 14507
0.000091 - SELECT * FROM bb_topics WHERE topic_id=14507
0.000173 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14507 AND approved = 1
0.000138 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14507 AND approved = 1 AND post_id < 284547
0.000232 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=14507 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000155 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =14507
0.000254 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001248 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000555 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000230 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000825 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000159 - SELECT * FROM groups
0.000382 - SELECT * FROM bb_forums ORDER BY forum_order
0.000166 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000297 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000208 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.138.138.144'
0.000136 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1713564321, '3.138.138.144', 5)
0.000171 - SELECT * FROM online
0.000243 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.138.138.144'
0.000120 - UPDATE online SET online_updated=1713564321, online_module = 5 WHERE online_uid = 0 AND online_ip='3.138.138.144'
0.000135 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.138.138.144'
0.000112 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1713564321, '3.138.138.144', 6, 14507)
0.000147 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000889 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('110.249.201.46','54.36.148.40','185.191.171.12','196.196.247.83','110.249.201.201','185.191.171.4','13.59.82.167','85.208.96.200','52.167.144.222','185.191.171.11','47.128.57.216','185.191.171.5','54.36.148.186','111.225.148.94','54.36.149.57','54.36.148.122','54.36.149.20','85.208.96.197','54.36.148.187','185.191.171.13','85.208.96.198','54.36.148.36','3.144.86.138','54.36.148.180','111.225.148.156','110.249.202.186','40.77.167.3','54.36.149.50','54.36.149.102','185.191.171.8','54.36.148.224','47.128.17.100','111.225.148.57','3.146.152.99','185.191.171.14','185.191.171.10','85.208.96.202','110.249.201.248','110.249.201.194','3.133.108.241','54.36.148.158','54.36.149.11','18.221.41.214','85.208.96.203','54.36.148.25','3.138.138.144','144.76.23.208','85.208.96.207','54.36.149.51','54.36.148.131','54.36.148.136','54.36.148.65','3.135.219.166','54.36.148.45','54.36.148.81','54.36.148.166','3.142.144.40','54.36.148.23','18.118.9.7','111.225.149.179','85.208.96.193','185.191.171.2','54.36.148.214','85.208.96.208','110.249.202.16','54.36.148.155','85.208.96.206') )
0.000157 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '14507'
0.000122 - SELECT * FROM bb_online WHERE (online_topic = '14507' AND online_uid <> '0')
0.000312 - SELECT * FROM `users` WHERE uid IN (6008,1779,841)
0.000147 - SELECT * FROM bb_online WHERE online_uid IN (6008,1779,841)
0.000155 - SELECT groupid FROM groups_users_link WHERE uid=6008
0.000161 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 6 AND rank_max >= 6 AND rank_special = 0
0.000108 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000082 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000111 - SELECT * FROM smiles
0.000167 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000154 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000162 - SELECT post_id FROM bb_posts WHERE topic_id = 14507 AND pid = 0
0.000327 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8223064 bytes
Page rendering a mis 0.129 seconde(s) pour charger
