Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (55) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000146 - SET NAMES 'utf8'
0.000067 - SET SQL_BIG_SELECTS = 1
0.000317 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7b893eeeb2b4d640d632de6453d23979'
0.000171 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000203 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=3058'
0.000144 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154'
0.000163 - INSERT INTO protector_access SET ip='54.236.59.154',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=3058',expire=UNIX_TIMESTAMP()+'60'
0.000334 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 3058
0.000288 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000059 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001098 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000282 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 193
0.000140 - SELECT * FROM bb_topics WHERE topic_id=193
0.000249 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1
0.000250 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1 AND post_id < 3058
0.000488 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=193 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000266 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =193
0.000052 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000114 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000087 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000457 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000390 - UPDATE online SET online_updated=1596448305, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000173 - SELECT * FROM online
0.000331 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000153 - UPDATE online SET online_updated=1596448305, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000257 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000212 - UPDATE bb_online SET online_updated= '1596448305', online_forum = '6', online_topic = '193' WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000251 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000323 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.166.190','54.236.59.154','114.119.165.26','40.77.167.242','114.119.167.117','144.76.23.207','114.119.163.218','40.77.167.59','114.119.166.244','207.46.13.12','157.55.39.137','40.77.167.195','114.119.160.139','114.119.167.169','63.143.42.253') )
0.000170 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '193'
0.000172 - SELECT * FROM bb_online WHERE (online_topic = '193' AND online_uid <> '0')
0.000671 - SELECT * FROM `users` WHERE uid IN (72,41,5,83,1,82,13,9,21)
0.000223 - SELECT * FROM bb_online WHERE online_uid IN (72,41,5,83,1,82,13,9,21)
0.000192 - SELECT groupid FROM groups_users_link WHERE uid=72
0.000263 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 804 AND rank_max >= 804 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7696168 bytes
XOOPS a mis 0.097 seconde(s) pour charger
XOOPS Boot a mis 0.028 seconde(s) pour charger
Module display a mis 0.010 seconde(s) pour charger
