Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (55) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000093 - SET NAMES 'utf8'
0.000243 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f27859aae563b83694a37e133bfb72e5'
0.000192 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000263 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=3421'
0.000144 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154'
0.000163 - INSERT INTO protector_access SET ip='54.236.59.154',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=3421',expire=UNIX_TIMESTAMP()+'60'
0.000300 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 3421
0.000172 - SELECT * FROM bb_forums WHERE forum_id = 6
0.001154 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000210 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 193
0.000320 - SELECT * FROM bb_topics WHERE topic_id=193
0.000243 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1
0.000228 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=193 AND approved = 1 AND post_id < 3421
0.000491 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=193 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000226 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =193
0.000336 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000217 - UPDATE online SET online_updated=1596444403, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000136 - SELECT * FROM online
0.000152 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000114 - UPDATE online SET online_updated=1596444403, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000169 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000139 - UPDATE bb_online SET online_updated= '1596444403', online_forum = '6', online_topic = '193' WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000168 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000221 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.149.50','114.119.164.234','114.119.167.169','114.119.164.173','114.119.163.218','54.236.59.154','40.77.167.59','114.119.166.244','40.77.167.155','114.119.166.190','40.77.167.195','114.119.160.139','114.119.166.165','54.36.148.142','114.119.167.117','90.57.140.124','90.57.105.111','63.143.42.253') )
0.000135 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '193'
0.000128 - SELECT * FROM bb_online WHERE (online_topic = '193' AND online_uid <> '0')
0.000413 - SELECT * FROM `users` WHERE uid IN (72,41,5,83,1,82,13,9,21)
0.000195 - SELECT * FROM bb_online WHERE online_uid IN (72,41,5,83,1,82,13,9,21)
0.000160 - SELECT groupid FROM groups_users_link WHERE uid=72
0.000224 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 804 AND rank_max >= 804 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7696120 bytes
XOOPS a mis 0.078 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
