Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (51) Requête(s) (47) Bloc(s) (5) Extra (2) Temporisation(5)
0.000097 - SET NAMES 'utf8'
0.000296 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'e35cd78be745975f914013ac2ddbc378'
0.000287 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000248 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=4488'
0.000122 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154'
0.000191 - INSERT INTO protector_access SET ip='54.236.59.154',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=4488',expire=UNIX_TIMESTAMP()+'60'
0.000405 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 4488
0.000148 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000924 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000212 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 289
0.000149 - SELECT * FROM bb_topics WHERE topic_id=289
0.000238 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=289 AND approved = 1
0.000173 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=289 AND approved = 1 AND post_id < 4488
0.000514 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=289 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000239 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =289
0.000069 - SELECT * FROM groups
0.000343 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000329 - UPDATE online SET online_updated=1596447938, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000162 - SELECT * FROM online
0.000152 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000145 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000234 - UPDATE online SET online_updated=1596447938, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000185 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000171 - UPDATE bb_online SET online_updated= '1596447938', online_forum = '6', online_topic = '289' WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000173 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000284 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('40.77.167.56','54.236.59.154','185.25.35.14','66.249.70.22','40.77.167.242','114.119.167.117','114.119.166.190','114.119.164.234','114.119.163.218','207.46.13.135','114.119.166.244','185.25.35.9','157.55.39.137','40.77.167.195','114.119.165.26','114.119.160.139','40.77.167.59','114.119.167.169','63.143.42.253') )
0.000130 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '289'
0.000132 - SELECT * FROM bb_online WHERE (online_topic = '289' AND online_uid <> '0')
0.000395 - SELECT * FROM `users` WHERE uid IN (178,41,82,21,37)
0.000191 - SELECT * FROM bb_online WHERE online_uid IN (178,41,82,21,37)
0.000183 - SELECT groupid FROM groups_users_link WHERE uid=178
0.000217 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
Total: 47
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7418552 bytes
XOOPS a mis 0.078 seconde(s) pour charger
XOOPS output init a mis 0.032 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
