Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (51) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000166 - SET NAMES 'utf8'
0.000081 - SET SQL_BIG_SELECTS = 1
0.000310 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '00933595595f79d7f123b8e23204ef54'
0.000123 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000141 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000271 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000299 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154' AND request_uri='/xoops/modules/newbb/viewtopic.php?post_id=5281'
0.000163 - SELECT COUNT(*) FROM protector_access WHERE ip='54.236.59.154'
0.000247 - INSERT INTO protector_access SET ip='54.236.59.154',request_uri='/xoops/modules/newbb/viewtopic.php?post_id=5281',expire=UNIX_TIMESTAMP()+'60'
0.000400 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 5281
0.000279 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000056 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001340 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000310 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 289
0.000149 - SELECT * FROM bb_topics WHERE topic_id=289
0.000304 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=289 AND approved = 1
0.000221 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=289 AND approved = 1 AND post_id < 5281
0.000552 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=289 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000257 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =289
0.000112 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.004916 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000086 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000101 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000056 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000122 - SELECT * FROM groups
0.000077 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000325 - DELETE FROM online WHERE online_updated < 1596444875
0.000218 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000288 - UPDATE online SET online_updated=1596445175, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000131 - SELECT * FROM online
0.000186 - UPDATE online SET online_updated=1596445175, online_module = 5 WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000174 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='54.236.59.154'
0.000233 - UPDATE bb_online SET online_updated= '1596445175', online_forum = '6', online_topic = '289' WHERE online_uid = 0 AND online_ip='54.236.59.154'
0.000300 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('40.77.167.56','90.57.105.111','54.36.148.63','114.119.163.218','114.119.164.173','40.77.167.195','114.119.165.26','40.77.167.59','114.119.166.244','207.46.13.135','207.46.13.12','46.119.186.141','54.36.148.173','114.119.166.165','114.119.166.190','114.119.167.117','114.119.167.169','54.236.59.154','63.143.42.253') )
0.000136 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '289'
0.000146 - SELECT * FROM bb_online WHERE (online_topic = '289' AND online_uid <> '0')
0.000384 - SELECT * FROM `users` WHERE uid IN (178,41,82,21,37)
0.000199 - SELECT * FROM bb_online WHERE online_uid IN (178,41,82,21,37)
0.000213 - SELECT groupid FROM groups_users_link WHERE uid=178
0.000209 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7420072 bytes
XOOPS a mis 0.122 seconde(s) pour charger
XOOPS Boot a mis 0.030 seconde(s) pour charger
Module init a mis 0.032 seconde(s) pour charger
Module display a mis 0.008 seconde(s) pour charger
