67 Personne(s) en ligne (63 Personne(s) connectée(s) sur Forum)
Invité(s): 67
Changer la lumière du compteur
De Avignon
Post(s): 8
je voudrais savoir si c'est possible de changer la couleur de la lumière du compteur et de l'horloge. Je voudrais passer du orange au bleu (bien plus joli!).
Contribution le : 26/06/2005 19:25
Re: Changer la lumière du compteur
regarde dans les article tout a deja etai effectuer
Contribution le : 26/06/2005 22:33
merci lionel
Contribution le : 28/06/2005 08:21
0.000060 - SET NAMES 'utf8'
0.000457 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000343 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f0e0f49adbd568c04e41beb6f3f907f1'
0.000173 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000777 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000466 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000204 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 5400
0.000147 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000827 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000967 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001060 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000180 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 343
0.000093 - SELECT * FROM bb_topics WHERE topic_id=343
0.000167 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=343 AND approved = 1
0.000141 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=343 AND approved = 1 AND post_id < 5400
0.000352 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=343 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000170 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =343
0.001066 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001136 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000478 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000225 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000970 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000143 - SELECT * FROM groups
0.000328 - SELECT * FROM bb_forums ORDER BY forum_order
0.000186 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000331 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000155 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.216.123.120'
0.000093 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1713512498, '18.216.123.120', 5)
0.000155 - SELECT * FROM online
0.000415 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.216.123.120'
0.000116 - UPDATE online SET online_updated=1713512498, online_module = 5 WHERE online_uid = 0 AND online_ip='18.216.123.120'
0.000139 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.216.123.120'
0.000111 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1713512498, '18.216.123.120', 6, 343)
0.000156 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000864 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.18','85.208.96.195','185.191.171.5','40.77.167.50','110.249.202.116','85.208.96.206','54.36.148.144','111.225.149.59','54.36.148.93','85.208.96.201','110.249.202.176','40.77.167.71','54.36.148.33','185.191.171.13','110.249.202.113','47.128.116.212','54.36.149.5','185.191.171.4','85.208.96.207','54.36.148.246','54.36.148.205','85.208.96.212','54.36.148.170','85.208.96.202','185.191.171.11','54.36.148.71','52.167.144.187','110.249.201.117','54.36.148.230','54.36.149.49','110.249.201.144','54.36.148.242','54.36.148.235','110.249.201.170','85.208.96.199','85.208.96.193','54.36.148.152','18.216.123.120','110.249.201.88','85.208.96.196','54.36.148.147','40.77.167.33','54.36.149.30','216.244.66.230','185.191.171.15','110.249.202.175','110.249.201.133','111.225.149.10','54.36.148.59','3.146.255.127','54.36.148.95','18.118.166.98','47.128.33.27','110.249.201.100','110.249.202.114','54.36.149.0','85.208.96.211','54.36.149.26','54.36.149.16','85.208.96.198','54.36.149.73','18.217.116.183','54.36.148.89') )
0.000132 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '343'
0.000116 - SELECT * FROM bb_online WHERE (online_topic = '343' AND online_uid <> '0')
0.000297 - SELECT * FROM `users` WHERE uid IN (204,5,1)
0.000126 - SELECT * FROM bb_online WHERE online_uid IN (204,5,1)
0.000125 - SELECT groupid FROM groups_users_link WHERE uid=204
0.000152 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8 AND rank_max >= 8 AND rank_special = 0
0.000103 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000077 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000105 - SELECT * FROM smiles
0.000139 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000089 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 7
0.000148 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000161 - SELECT post_id FROM bb_posts WHERE topic_id = 343 AND pid = 0
0.000374 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8226136 bytes
