Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (39) Requête(s) (46) Bloc(s) (5) Extra (2) Temporisation(5)
0.000096 - SET NAMES 'utf8'
0.000069 - SET SQL_BIG_SELECTS = 1
0.000143 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0435990c93d234d3eb11a87d9e4d2d0b'
0.000136 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000195 - SELECT COUNT(*) FROM protector_access WHERE ip='35.168.111.204' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=1117'
0.000120 - SELECT COUNT(*) FROM protector_access WHERE ip='35.168.111.204'
0.000159 - INSERT INTO protector_access SET ip='35.168.111.204',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=1117',expire=UNIX_TIMESTAMP()+'60'
0.000198 - SELECT * FROM bb_topics WHERE topic_id=1117
0.000054 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000041 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000231 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 1117
0.000042 - SELECT * FROM bb_topics WHERE topic_id=1117
0.000187 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=1117 AND approved = 1
0.000247 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=1117 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000171 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =1117
0.000082 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000397 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='35.168.111.204'
0.000208 - UPDATE online SET online_updated=1593890158, online_module = 5 WHERE online_uid = 0 AND online_ip='35.168.111.204'
0.000122 - SELECT * FROM online
0.000227 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='35.168.111.204'
0.000130 - UPDATE online SET online_updated=1593890158, online_module = 5 WHERE online_uid = 0 AND online_ip='35.168.111.204'
0.000229 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='35.168.111.204'
0.000141 - UPDATE bb_online SET online_updated= '1593890158', online_forum = '6', online_topic = '1117' WHERE online_uid = 0 AND online_ip='35.168.111.204'
0.000153 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000188 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('63.143.42.253','157.55.39.57','207.46.13.48','207.46.13.202','157.55.39.230','114.119.166.244','35.168.111.204','114.119.166.190','114.119.160.139','66.249.70.22','114.119.163.218','114.119.164.173') )
0.000109 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '1117'
0.000165 - SELECT * FROM bb_online WHERE (online_topic = '1117' AND online_uid <> '0')
0.000250 - SELECT * FROM `users` WHERE uid IN (257,96)
0.000114 - SELECT * FROM bb_online WHERE online_uid IN (257,96)
0.000192 - SELECT groupid FROM groups_users_link WHERE uid=257
0.000158 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 123 AND rank_max >= 123 AND rank_special = 0
Total: 46
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 6938192 bytes
XOOPS a mis 0.078 seconde(s) pour charger
Module display a mis 0.006 seconde(s) pour charger
