Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (52) Requête(s) (46) Bloc(s) (5) Extra (2) Temporisation(5)
0.000112 - SET NAMES 'utf8'
0.000264 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '2c01d675ca55802a8c0b14d417509d0a'
0.000118 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.001759 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.001412 - SELECT COUNT(*) FROM protector_access WHERE ip='34.239.149.34' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=12224'
0.000421 - SELECT COUNT(*) FROM protector_access WHERE ip='34.239.149.34'
0.000322 - INSERT INTO protector_access SET ip='34.239.149.34',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=12224',expire=UNIX_TIMESTAMP()+'60'
0.000423 - SELECT * FROM bb_topics WHERE topic_id=12224
0.000059 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000041 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000275 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 12224
0.000043 - SELECT * FROM bb_topics WHERE topic_id=12224
0.002144 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=12224 AND approved = 1
0.001969 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=12224 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000571 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =12224
0.000067 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000059 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000432 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.239.149.34'
0.000411 - UPDATE online SET online_updated=1594098348, online_module = 5 WHERE online_uid = 0 AND online_ip='34.239.149.34'
0.000209 - SELECT * FROM online
0.000170 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000171 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.239.149.34'
0.000236 - UPDATE online SET online_updated=1594098348, online_module = 5 WHERE online_uid = 0 AND online_ip='34.239.149.34'
0.000186 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.239.149.34'
0.000352 - UPDATE bb_online SET online_updated= '1594098348', online_forum = '6', online_topic = '12224' WHERE online_uid = 0 AND online_ip='34.239.149.34'
0.000199 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000184 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.166.165','114.119.167.117','63.143.42.253','114.119.165.26','34.239.149.34','114.119.167.169','114.119.166.190','114.119.166.244','157.55.39.9','114.119.164.173','114.119.163.218','157.55.39.230') )
0.000181 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '12224'
0.000150 - SELECT * FROM bb_online WHERE (online_topic = '12224' AND online_uid <> '0')
0.001660 - SELECT * FROM `users` WHERE uid IN (4518,3843,4282,21,2633,3442,4414,1587)
0.000153 - SELECT * FROM bb_online WHERE online_uid IN (4518,3843,4282,21,2633,3442,4414,1587)
0.000392 - SELECT groupid FROM groups_users_link WHERE uid=4518
0.000218 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 22 AND rank_max >= 22 AND rank_special = 0
Total: 46
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7564896 bytes
XOOPS a mis 0.088 seconde(s) pour charger
Module display a mis 0.009 seconde(s) pour charger
