Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (55) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000161 - SET NAMES 'utf8'
0.000077 - SET SQL_BIG_SELECTS = 1
0.000192 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000344 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '271809d4b41768a195a6883ce1df4bf3'
0.000127 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000096 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000134 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000180 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000321 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=13101'
0.000225 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29'
0.000332 - INSERT INTO protector_access SET ip='34.229.119.29',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=13101',expire=UNIX_TIMESTAMP()+'60'
0.002546 - SELECT * FROM bb_topics WHERE topic_id=13101
0.000087 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000079 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000094 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000080 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000287 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 13101
0.000138 - SELECT * FROM bb_topics WHERE topic_id=13101
0.029700 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=13101 AND approved = 1
0.016847 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=13101 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000728 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =13101
0.000087 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000347 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000177 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1594870792, '34.229.119.29', 5)
0.000190 - SELECT * FROM online
0.000220 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000174 - UPDATE online SET online_updated=1594870792, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000192 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.001108 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1594870792, '34.229.119.29', 6, 13101)
0.000291 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.167.117','114.119.165.26','114.119.167.169','87.101.94.198','114.119.160.139','114.119.166.244','185.25.35.9','114.119.164.173','40.77.167.173','157.55.39.76','114.119.166.190','207.46.13.125','40.77.167.61','110.82.169.126','114.119.166.165','34.229.119.29','114.119.164.234','157.55.39.108','63.143.42.253') )
0.000192 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '13101'
0.000143 - SELECT * FROM bb_online WHERE (online_topic = '13101' AND online_uid <> '0')
0.000489 - SELECT * FROM `users` WHERE uid IN (3843,4282,3711,21,5,4414,841,3347,3379,1778)
0.000201 - SELECT * FROM bb_online WHERE online_uid IN (3843,4282,3711,21,5,4414,841,3347,3379,1778)
0.000182 - SELECT groupid FROM groups_users_link WHERE uid=3843
0.000220 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 119 AND rank_max >= 119 AND rank_special = 0
0.000182 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000070 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7756424 bytes
XOOPS a mis 0.126 seconde(s) pour charger
Module init a mis 0.067 seconde(s) pour charger
XOOPS output init a mis 0.031 seconde(s) pour charger
Module display a mis 0.009 seconde(s) pour charger
