Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (41) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000255 - SET NAMES 'utf8'
0.000067 - SET SQL_BIG_SELECTS = 1
0.000180 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '8be526136a50836b2288a1f347fb10b1'
0.000267 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000178 - SELECT COUNT(*) FROM protector_access WHERE ip='3.228.21.204' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=13361'
0.000198 - SELECT COUNT(*) FROM protector_access WHERE ip='3.228.21.204'
0.000204 - INSERT INTO protector_access SET ip='3.228.21.204',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=13361',expire=UNIX_TIMESTAMP()+'60'
0.012941 - SELECT * FROM bb_topics WHERE topic_id=13361
0.000101 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000152 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000043 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000396 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 13361
0.000134 - SELECT * FROM bb_topics WHERE topic_id=13361
0.000318 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=13361 AND approved = 1
0.017805 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=13361 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000435 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =13361
0.000153 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000159 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000048 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000238 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.228.21.204'
0.000170 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1594465942, '3.228.21.204', 5)
0.000122 - SELECT * FROM online
0.000262 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.228.21.204'
0.000124 - UPDATE online SET online_updated=1594465942, online_module = 5 WHERE online_uid = 0 AND online_ip='3.228.21.204'
0.000133 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.228.21.204'
0.000115 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1594465942, '3.228.21.204', 6, 13361)
0.000203 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000247 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.165.26','114.119.164.173','52.201.217.210','40.77.167.160','40.77.167.141','185.25.35.13','17.58.97.78','114.119.164.234','54.36.149.2','63.143.42.253','40.77.167.68','207.46.13.5','40.77.167.182','3.228.21.204','114.119.166.165','114.119.163.218','54.36.148.176','114.119.167.117') )
0.000112 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '13361'
0.000141 - SELECT * FROM bb_online WHERE (online_topic = '13361' AND online_uid <> '0')
0.000393 - SELECT * FROM `users` WHERE uid IN (4989,1315)
0.000143 - SELECT * FROM bb_online WHERE online_uid IN (4989,1315)
0.000047 - SELECT groupid FROM groups_users_link WHERE uid=4989
0.000054 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1058 AND rank_max >= 1058 AND rank_special = 0
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7013912 bytes
XOOPS a mis 0.107 seconde(s) pour charger
Module init a mis 0.048 seconde(s) pour charger
XOOPS output init a mis 0.032 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
