Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (39) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000187 - SET NAMES 'utf8'
0.000123 - SET SQL_BIG_SELECTS = 1
0.000278 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '4a2a02b6d5aeeeecffc5c09980b7f29a'
0.000151 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000329 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=14186'
0.000209 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29'
0.000182 - INSERT INTO protector_access SET ip='34.229.119.29',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=14186',expire=UNIX_TIMESTAMP()+'60'
0.005779 - SELECT * FROM bb_topics WHERE topic_id=14186
0.000053 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000051 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000325 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 14186
0.000053 - SELECT * FROM bb_topics WHERE topic_id=14186
0.023615 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14186 AND approved = 1
0.009450 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=14186 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.001874 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =14186
0.000065 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000056 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000128 - SELECT * FROM groups
0.000111 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000075 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000558 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000244 - UPDATE online SET online_updated=1594872720, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000166 - SELECT * FROM online
0.000155 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.004708 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000148 - UPDATE online SET online_updated=1594872720, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000220 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000174 - UPDATE bb_online SET online_updated= '1594872720', online_forum = '6', online_topic = '14186' WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000251 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000233 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.167.117','114.119.166.165','114.119.167.169','114.119.164.173','114.119.160.139','114.119.166.190','207.46.13.125','40.77.167.173','114.119.165.26','114.119.163.218','114.119.166.244','34.229.119.29','157.55.39.108','66.249.70.20','157.55.39.76','63.143.42.253') )
0.000132 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '14186'
0.000155 - SELECT * FROM bb_online WHERE (online_topic = '14186' AND online_uid <> '0')
0.006847 - SELECT * FROM `users` WHERE uid IN (5644,83)
0.000209 - SELECT * FROM bb_online WHERE online_uid IN (5644,83)
0.009991 - SELECT groupid FROM groups_users_link WHERE uid=5644
0.003831 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 16 AND rank_max >= 16 AND rank_special = 0
0.010491 - SELECT groupid FROM groups_users_link WHERE uid=83
0.000049 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 6952536 bytes
XOOPS a mis 0.153 seconde(s) pour charger
Module init a mis 0.057 seconde(s) pour charger
