Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (40) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000179 - SET NAMES 'utf8'
0.000133 - SET SQL_BIG_SELECTS = 1
0.000120 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000223 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '6cb7a234d6b91b1c1eebd13307b25059'
0.000081 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.002174 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000289 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=14507'
0.000195 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29'
0.000301 - INSERT INTO protector_access SET ip='34.229.119.29',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=14507',expire=UNIX_TIMESTAMP()+'60'
0.000179 - SELECT * FROM bb_topics WHERE topic_id=14507
0.000093 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000090 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000086 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000093 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000293 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 14507
0.000114 - SELECT * FROM bb_topics WHERE topic_id=14507
0.017106 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14507 AND approved = 1
0.000415 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=14507 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000634 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =14507
0.000070 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000125 - SELECT * FROM bb_forums ORDER BY forum_order
0.000359 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000451 - UPDATE online SET online_updated=1594870075, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000125 - SELECT * FROM online
0.000185 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000178 - UPDATE online SET online_updated=1594870075, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000154 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000266 - UPDATE bb_online SET online_updated= '1594870075', online_forum = '6', online_topic = '14507' WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000190 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000227 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.167.117','34.229.119.29','114.119.166.244','114.119.167.169','40.77.167.173','157.55.39.76','114.119.164.173','114.119.163.218','40.77.167.61','114.119.160.139','185.25.35.12','114.119.164.234','157.55.39.108','63.143.42.253') )
0.000112 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '14507'
0.000138 - SELECT * FROM bb_online WHERE (online_topic = '14507' AND online_uid <> '0')
0.000403 - SELECT * FROM `users` WHERE uid IN (6008,1779,841)
0.000128 - SELECT * FROM bb_online WHERE online_uid IN (6008,1779,841)
0.000143 - SELECT groupid FROM groups_users_link WHERE uid=6008
0.000186 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 6 AND rank_max >= 6 AND rank_special = 0
0.000058 - SELECT groupid FROM groups_users_link WHERE uid=1779
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7022968 bytes
XOOPS a mis 0.095 seconde(s) pour charger
Module init a mis 0.036 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
