92 Personne(s) en ligne (87 Personne(s) connectée(s) sur Forum)
Invité(s): 92
cuir décousus
De janzé 35
Post(s): 14
un petit avant après l'intervention de mme
ensuite remplacement du pommeau (il est en commande )
la fin sera débosselage et un gros nettoyage
Contribution le : 13/05/2015 16:05
Re: cuir décousus
De chateauroux
Post(s): 222
Excellent travail, comment a t elle procédé ? avec quel genre de fil ?
Contribution le : 18/02/2016 20:02
Re: cuir décousus
De haute normandie
Post(s): 24
Oui peut tu nous donner plus d'infos stp? j'ai le même souci
Beau boulot
Contribution le : 18/02/2016 20:12
0.000071 - SET NAMES 'utf8'
0.000494 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002985 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'e647990247763ea59f85dc40c996ff59'
0.000200 - SELECT * FROM modules WHERE dirname = 'newbb'
0.001827 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000566 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000184 - SELECT * FROM bb_topics WHERE topic_id=19550
0.000182 - SELECT * FROM bb_forums WHERE forum_id = 11
0.001526 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001015 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000914 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '11' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000190 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 19550
0.000103 - SELECT * FROM bb_topics WHERE topic_id=19550
0.000186 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19550 AND approved = 1
0.000251 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=19550 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000166 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =19550
0.000272 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001095 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000480 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000220 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000844 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000157 - SELECT * FROM groups
0.000328 - SELECT * FROM bb_forums ORDER BY forum_order
0.000167 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000292 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000189 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='13.59.82.167'
0.000134 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1713517772, '13.59.82.167', 5)
0.000174 - SELECT * FROM online
0.000182 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='13.59.82.167'
0.000100 - UPDATE online SET online_updated=1713517772, online_module = 5 WHERE online_uid = 0 AND online_ip='13.59.82.167'
0.000119 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='13.59.82.167'
0.000095 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1713517772, '13.59.82.167', 11, 19550)
0.000141 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000850 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.148.214','54.36.148.163','54.36.148.171','54.36.148.27','217.113.194.53','18.218.254.122','54.36.148.129','54.36.149.95','54.36.149.51','217.113.194.55','111.225.149.160','217.113.194.56','85.208.96.212','54.36.148.120','185.191.171.18','85.208.96.202','185.191.171.19','54.36.148.146','111.225.148.188','185.191.171.13','54.36.148.3','217.113.194.48','54.36.148.73','85.208.96.209','217.113.194.54','3.143.9.115','217.113.194.59','217.113.194.52','13.59.82.167','54.36.148.111','154.54.249.196','54.36.148.14','54.36.149.42','185.191.171.4','54.36.148.132','111.225.149.44','54.36.148.209','185.191.171.14','54.36.149.43','54.36.148.104','85.208.96.208','217.113.194.50','54.36.148.154','110.249.202.50','85.208.96.194','18.117.107.90','54.36.148.61','85.208.96.205','54.36.148.138','54.36.148.50','54.36.149.105','217.113.194.57','54.36.148.98','54.36.148.11','54.36.148.57','54.36.148.159','185.191.171.15','54.36.148.194','54.36.148.92','111.225.149.96','217.113.194.63','92.152.174.22','3.140.198.43','85.208.96.203','54.36.148.162','54.36.148.34','3.21.104.109','217.113.194.51','54.36.148.0','54.36.148.91','217.113.194.60','185.191.171.17','217.113.194.62','85.208.96.211','185.191.171.2','3.144.113.30','54.36.148.164','3.145.163.58','54.36.148.59','54.36.149.32','54.36.148.22','54.36.148.191','217.113.194.58','54.36.148.99','85.208.96.204','54.36.148.33','217.113.194.61') )
0.000127 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '19550'
0.000106 - SELECT * FROM bb_online WHERE (online_topic = '19550' AND online_uid <> '0')
0.000283 - SELECT * FROM `users` WHERE uid IN (13041,26578,26580)
0.000130 - SELECT * FROM bb_online WHERE online_uid IN (13041,26578,26580)
0.000114 - SELECT groupid FROM groups_users_link WHERE uid=13041
0.000145 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 14 AND rank_max >= 14 AND rank_special = 0
0.000097 - SELECT groupid FROM groups_users_link WHERE uid=26578
0.000119 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 222 AND rank_max >= 222 AND rank_special = 0
0.000097 - SELECT groupid FROM groups_users_link WHERE uid=26580
0.000370 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 24 AND rank_max >= 24 AND rank_special = 0
0.000120 - SELECT * FROM smiles
0.000164 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000151 - SELECT post_id FROM bb_posts WHERE topic_id = 19550 AND pid = 0
0.000333 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 50
Usage de la mémoire: 8203608 bytes
XOOPS a mis 0.252 seconde(s) pour charger
XOOPS Boot a mis 0.026 seconde(s) pour charger
Module display a mis 0.018 seconde(s) pour charger
Page rendering a mis 0.122 seconde(s) pour charger
