91 Personne(s) en ligne (90 Personne(s) connectée(s) sur Forum)
Invité(s): 91
Branchement ventilation clio r19 sur mégane
De 31
Post(s): 89
Salut salut
Est ce que quelqu'un aurait le schema electrique pour le branchement de la ventilation de r19 (clio...)?
Car les cosses ne sont pas les memes que sur la mégane
(J'ai vu le post de Stevenkart mais il n'explique pas le branchement)
Merci :)
Contribution le : 22/07/2016 14:45
0.000072 - SET NAMES 'utf8'
0.000434 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000186 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '887e2d0d003b0e8272c3285c1e18595d'
0.000178 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000837 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000492 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000171 - SELECT * FROM bb_topics WHERE topic_id=20279
0.000182 - SELECT * FROM bb_forums WHERE forum_id = 11
0.000750 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000930 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000931 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '11' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000186 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20279
0.000089 - SELECT * FROM bb_topics WHERE topic_id=20279
0.000175 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20279 AND approved = 1
0.000206 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20279 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000229 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20279
0.000249 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001039 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000493 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000224 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000769 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000135 - SELECT * FROM groups
0.000317 - SELECT * FROM bb_forums ORDER BY forum_order
0.000176 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000309 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000212 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.173.107'
0.000127 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1711712654, '34.229.173.107', 5)
0.000166 - SELECT * FROM online
0.000096 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000194 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.173.107'
0.000093 - UPDATE online SET online_updated=1711712654, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.173.107'
0.000126 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.229.173.107'
0.000086 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1711712654, '34.229.173.107', 11, 20279)
0.000149 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000961 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('216.244.66.230','54.36.149.67','54.36.148.76','54.36.148.238','54.36.148.196','54.36.148.204','3.236.98.81','54.36.148.84','52.90.131.200','54.36.148.50','54.36.148.67','54.36.149.78','54.36.148.192','54.36.148.10','54.36.149.60','54.36.149.68','54.36.148.233','54.36.148.77','54.36.148.27','54.36.149.39','54.36.148.169','54.36.148.154','3.237.31.131','54.36.148.64','54.36.148.29','54.36.149.79','3.82.58.213','54.36.148.73','54.36.149.61','54.36.148.114','54.36.149.87','34.229.173.107','54.36.148.221','54.36.148.105','54.36.148.59','54.36.148.208','54.36.148.122','54.36.149.91','54.36.148.193','54.36.149.66','40.77.167.50','54.36.149.25','54.36.148.49','207.46.13.14','54.36.149.63','54.36.148.254','54.36.148.115','54.36.148.11','54.36.148.145','3.236.57.1','54.36.148.246','54.36.148.15','54.36.148.26','54.36.148.179','54.36.148.106','54.36.148.130','54.36.148.241','54.36.149.81','54.36.148.194','54.36.149.3','54.36.149.11','54.36.148.0','54.36.148.131','54.36.148.160','54.36.149.9','54.36.148.75','54.36.148.219','54.36.148.228','54.167.199.134','54.36.148.24','54.36.148.178','54.226.94.217','54.36.148.144','54.36.148.157','54.36.149.32','3.81.23.50','54.36.149.90','54.36.149.62','54.36.149.99','54.36.148.213','54.36.148.237','54.36.148.239','54.36.148.66','18.207.98.249','3.91.249.156','54.36.148.248','54.36.148.172','54.36.148.222','54.36.149.82','54.36.149.69') )
0.000123 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20279'
0.000107 - SELECT * FROM bb_online WHERE (online_topic = '20279' AND online_uid <> '0')
0.000188 - SELECT * FROM `users` WHERE uid IN (11689)
0.000131 - SELECT * FROM bb_online WHERE online_uid IN (11689)
0.000167 - SELECT groupid FROM groups_users_link WHERE uid=11689
0.000162 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 89 AND rank_max >= 89 AND rank_special = 0
0.000145 - SELECT * FROM smiles
0.000198 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000146 - SELECT post_id FROM bb_posts WHERE topic_id = 20279 AND pid = 0
0.000386 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 46
Usage de la mémoire: 7977832 bytes
XOOPS a mis 0.126 seconde(s) pour charger
Module display a mis 0.016 seconde(s) pour charger
