41 Personne(s) en ligne (24 Personne(s) connectée(s) sur Forum)
Invité(s): 41
tenue de route
Post(s): 8
Bonjour à tous, petite question du soir à part le moteur et quelques changement niveau carrosserie entre la phase 1 et la 2, y a t-il une modification sur les trains roulant ou une quelconque modif au niveau de la caisse?
Contribution le : 29/12/2016 17:23
Re: tenue de route
Oui la caisse est différente, enfin le chassis, il a été renforcé sur ph2.
Contribution le : 30/12/2016 08:14
0.000102 - SET NAMES 'utf8'
0.000562 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002789 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'c40486293dc13caa972b6f077180f537'
0.000197 - SELECT * FROM modules WHERE dirname = 'newbb'
0.001981 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000526 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000221 - SELECT * FROM bb_topics WHERE topic_id=20464
0.000172 - SELECT * FROM bb_forums WHERE forum_id = 13
0.001082 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000998 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000992 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '13' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000190 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20464
0.000092 - SELECT * FROM bb_topics WHERE topic_id=20464
0.000171 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20464 AND approved = 1
0.000248 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20464 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000206 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20464
0.000242 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000997 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000492 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000242 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000786 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000316 - SELECT * FROM bb_forums ORDER BY forum_order
0.000203 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000296 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000220 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.12.162.179'
0.000127 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714044075, '3.12.162.179', 5)
0.000117 - SELECT * FROM online
0.000206 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.12.162.179'
0.000102 - UPDATE online SET online_updated=1714044075, online_module = 5 WHERE online_uid = 0 AND online_ip='3.12.162.179'
0.000119 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.12.162.179'
0.000102 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714044075, '3.12.162.179', 13, 20464)
0.000148 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000317 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('40.77.167.3','111.225.148.121','110.249.202.101','110.249.202.137','111.225.148.101','3.15.229.113','3.15.219.217','110.249.201.116','18.221.146.223','111.225.148.92','3.144.97.189','3.142.250.114','3.144.17.45','40.77.167.33','111.225.149.66','40.77.167.143','47.128.34.186','3.142.53.68','207.46.13.111','47.128.99.111','111.225.149.205','110.249.202.117','3.12.162.179','111.225.148.236') )
0.000104 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20464'
0.000112 - SELECT * FROM bb_online WHERE (online_topic = '20464' AND online_uid <> '0')
0.000280 - SELECT * FROM `users` WHERE uid IN (26952,21)
0.000116 - SELECT * FROM bb_online WHERE online_uid IN (26952,21)
0.000184 - SELECT groupid FROM groups_users_link WHERE uid=26952
0.000169 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8 AND rank_max >= 8 AND rank_special = 0
0.000104 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000126 - SELECT * FROM smiles
0.000161 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000190 - SELECT post_id FROM bb_posts WHERE topic_id = 20464 AND pid = 0
0.002428 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 48
Usage de la mémoire: 8108072 bytes
