161 Personne(s) en ligne (142 Personne(s) connectée(s) sur Forum)
Invité(s): 161
Eclairage boite à gant
De Isère
Post(s): 201
salut à tous
j'ai changé mon ampoule de boite à gant mais celle-ci ne fonctionne toujours pas. Quelqu'un s'est-il d'ou cela peut provenir sachant que le reste de l'éclairage du tableau de bord et autoradio fonctionne.
J'ai une mégane 1 cabriolet phase 2
Contribution le : 09/03/2017 22:27
0.000087 - SET NAMES 'utf8'
0.000535 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000323 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f2a1029010950602423dd667689e4b0d'
0.000223 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002039 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000629 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000191 - SELECT * FROM bb_topics WHERE topic_id=20555
0.000199 - SELECT * FROM bb_forums WHERE forum_id = 33
0.001926 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001074 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000887 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '33' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000192 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20555
0.000089 - SELECT * FROM bb_topics WHERE topic_id=20555
0.000197 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20555 AND approved = 1
0.000243 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20555 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000198 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20555
0.000261 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000976 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000512 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000282 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000857 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000160 - SELECT * FROM groups
0.000319 - SELECT * FROM bb_forums ORDER BY forum_order
0.000206 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000305 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000243 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.144.127.232'
0.000143 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714124849, '3.144.127.232', 5)
0.000206 - SELECT * FROM online
0.000371 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.144.127.232'
0.000127 - UPDATE online SET online_updated=1714124849, online_module = 5 WHERE online_uid = 0 AND online_ip='3.144.127.232'
0.000143 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.144.127.232'
0.000107 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714124849, '3.144.127.232', 33, 20555)
0.000181 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001456 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.149.14','54.36.148.27','54.36.149.61','54.36.148.7','54.36.149.17','54.36.148.22','54.36.148.132','54.36.148.137','18.226.251.22','54.36.148.235','54.36.148.67','54.36.148.202','54.36.148.122','54.36.148.161','54.36.149.27','54.36.148.65','54.36.148.230','66.249.64.38','54.36.149.11','54.36.148.107','54.36.148.23','54.36.149.41','54.36.148.36','54.36.148.236','54.36.148.187','54.36.149.45','54.36.148.0','54.36.148.113','157.55.39.204','54.36.148.85','54.36.149.90','54.36.148.232','54.36.148.210','54.36.148.57','54.36.148.59','54.36.148.144','54.36.148.49','54.36.148.238','54.36.148.103','54.36.148.173','54.36.148.32','54.36.149.44','54.36.148.145','54.36.148.242','54.36.148.134','130.180.231.214','54.36.148.121','47.128.17.128','54.36.148.5','54.36.148.169','54.36.148.9','54.36.148.128','54.36.149.36','54.36.149.25','54.36.149.64','52.167.144.181','54.36.148.31','85.208.96.204','54.36.148.25','110.249.202.201','54.36.149.37','54.36.148.170','54.36.149.22','54.36.148.12','54.36.148.64','54.36.148.77','54.36.148.97','54.36.148.8','54.36.149.68','54.36.148.207','54.36.148.133','52.167.144.11','110.249.201.146','54.36.148.2','54.36.149.69','54.36.148.162','54.36.149.21','52.167.144.230','3.139.86.56','3.144.127.232','54.36.148.76','54.36.148.6','54.36.148.191','85.208.96.211','54.36.149.87','54.36.148.29','54.36.148.231','47.128.34.3','3.145.183.137','54.36.148.228','47.128.39.239','54.36.148.206','54.36.148.95','54.36.148.61','54.36.148.156','54.36.148.131','54.36.149.96','54.36.149.100','54.36.148.205','54.36.148.147','54.36.148.233','40.77.167.76','54.36.149.98','54.36.148.251','54.36.148.43','54.36.148.69','54.36.148.120','110.249.201.70','54.36.149.60','54.36.149.4','110.249.201.135','54.36.149.94','85.208.96.199','54.36.148.216','54.36.149.62','185.191.171.1','54.36.148.1','54.36.148.4','54.36.148.184','54.36.148.204','54.36.148.234','54.36.149.78','54.36.148.185','54.36.148.143','54.36.148.93','54.36.149.101','54.36.148.15','54.36.149.12','54.36.148.80','54.36.149.74','54.36.148.55','54.36.148.177','66.249.70.70','54.36.148.13','54.36.148.87','185.191.171.6','54.36.148.53','54.36.149.71','54.36.148.220','54.36.148.179','54.36.148.46','54.36.148.182') )
0.000155 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20555'
0.000129 - SELECT * FROM bb_online WHERE (online_topic = '20555' AND online_uid <> '0')
0.000200 - SELECT * FROM `users` WHERE uid IN (2120)
0.000116 - SELECT * FROM bb_online WHERE online_uid IN (2120)
0.000169 - SELECT groupid FROM groups_users_link WHERE uid=2120
0.000105 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 9
0.000119 - SELECT * FROM smiles
0.000188 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000166 - SELECT post_id FROM bb_posts WHERE topic_id = 20555 AND pid = 0
0.000340 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 46
Usage de la mémoire: 7979184 bytes
XOOPS a mis 0.170 seconde(s) pour charger
Module display a mis 0.018 seconde(s) pour charger
