34 Personne(s) en ligne (28 Personne(s) connectée(s) sur Forum)
Invité(s): 34
[1,9 DCI 120 CC] présentation
Post(s): 2
Bonjour à tous,
Groflan 31 ans, Aix-en-provence
j'ai une mégane CC de 2004 que j'ai acheté HS et que j'ai réanimé.
J'ai bien entendu rencontré quelques problème
Contribution le : 19/03/2017 17:52
0.000072 - SET NAMES 'utf8'
0.000477 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002874 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '884fb1e382283acff524aa053c32180b'
0.000202 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002011 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000545 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000198 - SELECT * FROM bb_topics WHERE topic_id=20570
0.000173 - SELECT * FROM bb_forums WHERE forum_id = 23
0.001272 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001031 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000964 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000189 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20570
0.000092 - SELECT * FROM bb_topics WHERE topic_id=20570
0.000168 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20570 AND approved = 1
0.000214 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20570 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000149 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20570
0.000249 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001038 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000498 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000246 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000801 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000125 - SELECT * FROM groups
0.000293 - SELECT * FROM bb_forums ORDER BY forum_order
0.000195 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000293 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000170 - DELETE FROM online WHERE online_updated < 1714169429
0.000140 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.221.239.148'
0.000116 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714169729, '18.221.239.148', 5)
0.000122 - SELECT * FROM online
0.000097 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000169 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.221.239.148'
0.000136 - UPDATE online SET online_updated=1714169730, online_module = 5 WHERE online_uid = 0 AND online_ip='18.221.239.148'
0.000122 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.221.239.148'
0.000087 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714169730, '18.221.239.148', 23, 20570)
0.000123 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000315 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('110.249.201.96','40.77.167.36','3.128.203.143','40.77.167.70','111.225.149.233','207.46.13.130','111.225.149.87','3.144.143.31','111.225.148.77','3.144.238.20','3.15.218.254','110.249.201.172','3.144.35.148','3.142.198.129','47.128.22.44','18.119.118.99','213.152.15.7','110.249.201.242','18.221.13.173','111.225.149.163','110.249.202.142','18.221.239.148','40.77.167.33','18.119.104.238','18.116.36.221','111.225.148.17','18.221.15.15','111.225.149.20') )
0.000107 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20570'
0.000110 - SELECT * FROM bb_online WHERE (online_topic = '20570' AND online_uid <> '0')
0.000207 - SELECT * FROM `users` WHERE uid IN (27052)
0.000141 - SELECT * FROM bb_online WHERE online_uid IN (27052)
0.000175 - SELECT groupid FROM groups_users_link WHERE uid=27052
0.000177 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 2 AND rank_max >= 2 AND rank_special = 0
0.000121 - SELECT * FROM smiles
0.000164 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000160 - SELECT post_id FROM bb_posts WHERE topic_id = 20570 AND pid = 0
0.000365 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 47
Usage de la mémoire: 7978480 bytes
Module display a mis 0.016 seconde(s) pour charger
