Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (51) Requête(s) (46) Bloc(s) (5) Extra (2) Temporisation(5)
0.000171 - SET NAMES 'utf8'
0.000203 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '77a666384819ee65bb233bf31859f447'
0.000161 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000295 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=289'
0.000200 - SELECT COUNT(*) FROM protector_access WHERE ip='34.229.119.29'
0.000199 - INSERT INTO protector_access SET ip='34.229.119.29',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=289',expire=UNIX_TIMESTAMP()+'60'
0.000310 - SELECT * FROM bb_topics WHERE topic_id=289
0.000055 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000044 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000293 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 289
0.000130 - SELECT * FROM bb_topics WHERE topic_id=289
0.004232 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=289 AND approved = 1
0.042902 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=289 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000527 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =289
0.000072 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000097 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000172 - SELECT * FROM groups
0.000151 - SELECT * FROM bb_forums ORDER BY forum_order
0.000121 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000160 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000574 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000308 - UPDATE online SET online_updated=1594866484, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000205 - SELECT * FROM online
0.000306 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000135 - UPDATE online SET online_updated=1594866484, online_module = 5 WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000182 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.229.119.29'
0.000384 - UPDATE bb_online SET online_updated= '1594866484', online_forum = '6', online_topic = '289' WHERE online_uid = 0 AND online_ip='34.229.119.29'
0.000261 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.160.139','207.46.13.125','114.119.164.234','114.119.167.169','157.55.39.76','114.119.165.26','114.119.164.173','40.77.167.173','114.119.167.117','114.119.163.218','144.76.23.194','185.25.35.12','114.119.166.165','40.77.167.61','157.55.39.108','114.119.166.244','34.229.119.29','63.143.42.253') )
0.000159 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '289'
0.000170 - SELECT * FROM bb_online WHERE (online_topic = '289' AND online_uid <> '0')
0.000375 - SELECT * FROM `users` WHERE uid IN (178,41,82,21,37)
0.000182 - SELECT * FROM bb_online WHERE online_uid IN (178,41,82,21,37)
0.000189 - SELECT groupid FROM groups_users_link WHERE uid=178
0.000224 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
Total: 46
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7419056 bytes
XOOPS a mis 0.147 seconde(s) pour charger
Module init a mis 0.069 seconde(s) pour charger
Module display a mis 0.008 seconde(s) pour charger
