Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (40) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000202 - SET NAMES 'utf8'
0.000119 - SET SQL_BIG_SELECTS = 1
0.000189 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '200fe865ff06fe8e9450400c103ff916'
0.000168 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000225 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000282 - SELECT COUNT(*) FROM protector_access WHERE ip='3.234.241.200' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=343'
0.000154 - SELECT COUNT(*) FROM protector_access WHERE ip='3.234.241.200'
0.000161 - INSERT INTO protector_access SET ip='3.234.241.200',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=343',expire=UNIX_TIMESTAMP()+'60'
0.000206 - SELECT * FROM bb_topics WHERE topic_id=343
0.000078 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000041 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000223 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 343
0.000075 - SELECT * FROM bb_topics WHERE topic_id=343
0.000448 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=343 AND approved = 1
0.000736 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=343 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000264 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =343
0.000060 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000277 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.234.241.200'
0.000303 - UPDATE online SET online_updated=1594717642, online_module = 5 WHERE online_uid = 0 AND online_ip='3.234.241.200'
0.000126 - SELECT * FROM online
0.000199 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.234.241.200'
0.000131 - UPDATE online SET online_updated=1594717642, online_module = 5 WHERE online_uid = 0 AND online_ip='3.234.241.200'
0.000163 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.234.241.200'
0.000288 - UPDATE bb_online SET online_updated= '1594717642', online_forum = '6', online_topic = '343' WHERE online_uid = 0 AND online_ip='3.234.241.200'
0.000231 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.167.169','66.249.70.24','40.77.167.91','114.119.166.165','3.234.241.200','157.55.39.108','114.119.160.139','63.143.42.253','207.46.13.151','114.119.163.218','114.119.166.244','90.57.29.81','114.119.164.234','157.55.39.254','207.46.13.204','157.55.39.137','114.119.167.117') )
0.000129 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '343'
0.000174 - SELECT * FROM bb_online WHERE (online_topic = '343' AND online_uid <> '0')
0.000335 - SELECT * FROM `users` WHERE uid IN (204,5,1)
0.000125 - SELECT * FROM bb_online WHERE online_uid IN (204,5,1)
0.000202 - SELECT groupid FROM groups_users_link WHERE uid=204
0.000114 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8 AND rank_max >= 8 AND rank_special = 0
0.000139 - SELECT groupid FROM groups_users_link WHERE uid=5
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7024384 bytes
XOOPS a mis 0.076 seconde(s) pour charger
XOOPS output init a mis 0.032 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
