106 Personne(s) en ligne (100 Personne(s) connectée(s) sur Forum)
Invité(s): 106
siege bacquet..
De le havre
Post(s): 565
quelqu un possede t il une megane avec des sieges bacquet si oui peut il poster des photos ici merci... :vroom1
Contribution le : 16/08/2007 09:44
Re: siege bacquet..
De dijon les environ
Post(s): 766
oui moi j'en ai je mets des photos dans la journée.
Contribution le : 16/08/2007 10:36
megane coupé 1.6L 16V
:vroom1...
0.000101 - SET NAMES 'utf8'
0.000794 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.002878 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f4070e4074423b81d2a26048af187923'
0.000181 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002022 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000555 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000193 - SELECT * FROM bb_topics WHERE topic_id=4792
0.000256 - SELECT * FROM bb_forums WHERE forum_id = 6
0.001519 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.001234 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001068 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000200 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 4792
0.000091 - SELECT * FROM bb_topics WHERE topic_id=4792
0.000178 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=4792 AND approved = 1
0.000219 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=4792 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000170 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =4792
0.000256 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.001162 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000548 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000259 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000903 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000224 - SELECT * FROM groups
0.000341 - SELECT * FROM bb_forums ORDER BY forum_order
0.000195 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000321 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000993 - DELETE FROM online WHERE online_updated < 1711723442
0.000152 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.206.1.144'
0.000121 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1711723742, '34.206.1.144', 5)
0.000150 - SELECT * FROM online
0.000269 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='34.206.1.144'
0.000120 - UPDATE online SET online_updated=1711723742, online_module = 5 WHERE online_uid = 0 AND online_ip='34.206.1.144'
0.000129 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='34.206.1.144'
0.000114 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1711723742, '34.206.1.144', 6, 4792)
0.000170 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001641 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.148.225','54.36.148.234','54.36.148.61','54.36.148.75','54.36.149.70','54.36.148.187','3.94.99.173','207.46.13.154','107.20.123.227','54.36.149.28','35.175.246.88','54.36.149.80','54.36.148.140','54.36.148.23','54.36.148.100','54.36.149.0','54.36.148.253','54.36.148.53','54.36.149.58','54.36.148.107','54.36.149.94','54.36.148.202','54.36.148.52','54.36.149.14','54.36.148.46','54.36.148.83','44.222.87.38','54.36.148.29','54.36.149.83','54.36.148.48','54.36.148.152','54.36.148.6','54.36.148.68','54.36.149.43','54.36.149.57','18.209.230.60','54.36.148.13','54.36.148.138','54.36.148.12','54.36.149.76','54.36.148.80','54.36.149.88','216.244.66.230','54.36.148.191','54.174.85.205','54.36.149.55','54.36.148.5','54.36.148.73','54.198.34.207','54.36.149.29','3.81.139.99','54.36.148.128','54.36.149.61','54.36.148.188','54.36.148.14','54.36.148.38','54.36.148.119','54.36.148.101','44.210.78.150','54.36.148.97','54.36.148.93','54.36.148.241','44.221.87.114','54.36.149.47','54.36.148.69','54.36.148.220','54.36.148.91','54.36.149.67','54.172.162.78','54.36.148.254','54.36.149.49','54.36.149.50','54.36.148.110','54.36.148.2','54.36.148.156','54.36.148.171','54.36.148.243','54.36.148.252','54.36.148.33','44.223.5.218','54.36.149.92','54.36.149.35','44.213.65.97','34.206.1.144','54.36.148.190','54.36.148.174','54.36.149.10','54.36.148.173','54.36.148.30','54.36.148.211','40.77.167.25','54.36.148.28','54.36.148.142','54.36.148.50','54.36.148.209','35.170.54.171','54.36.148.108','54.36.148.3','54.36.149.86','52.90.235.91') )
0.000154 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '4792'
0.000131 - SELECT * FROM bb_online WHERE (online_topic = '4792' AND online_uid <> '0')
0.000235 - SELECT * FROM `users` WHERE uid IN (1706,491)
0.000113 - SELECT * FROM bb_online WHERE online_uid IN (1706,491)
0.000175 - SELECT groupid FROM groups_users_link WHERE uid=1706
0.000109 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000114 - SELECT groupid FROM groups_users_link WHERE uid=491
0.000080 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 11
0.000106 - SELECT * FROM smiles
0.000136 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000158 - SELECT post_id FROM bb_posts WHERE topic_id = 4792 AND pid = 0
0.000489 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 49
Usage de la mémoire: 8111728 bytes
XOOPS a mis 0.761 seconde(s) pour charger
XOOPS output init a mis 0.353 seconde(s) pour charger
Page rendering a mis 0.350 seconde(s) pour charger
