Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (17) Deprécié(s) (41) Requête(s) (48) Bloc(s) (5) Extra (2) Temporisation(5)
0.000131 - SET NAMES 'utf8'
0.000064 - SET SQL_BIG_SELECTS = 1
0.000160 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '6a2bb2efd4f1bc259e52c0e0eec9f388'
0.000074 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000180 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000197 - SELECT COUNT(*) FROM protector_access WHERE ip='18.205.109.152' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=594'
0.000130 - SELECT COUNT(*) FROM protector_access WHERE ip='18.205.109.152'
0.000188 - INSERT INTO protector_access SET ip='18.205.109.152',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=594',expire=UNIX_TIMESTAMP()+'60'
0.000199 - SELECT * FROM bb_topics WHERE topic_id=594
0.000143 - SELECT * FROM bb_forums WHERE forum_id = 6
0.001122 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000256 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 594
0.000043 - SELECT * FROM bb_topics WHERE topic_id=594
0.000181 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=594 AND approved = 1
0.000296 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=594 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000250 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =594
0.000088 - SELECT * FROM groups
0.000124 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000385 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.205.109.152'
0.000192 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1593955571, '18.205.109.152', 5)
0.000131 - SELECT * FROM online
0.000176 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.205.109.152'
0.000180 - UPDATE online SET online_updated=1593955571, online_module = 5 WHERE online_uid = 0 AND online_ip='18.205.109.152'
0.000145 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.205.109.152'
0.000172 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1593955571, '18.205.109.152', 6, 594)
0.000268 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('207.46.13.202','114.119.166.165','63.143.42.253','114.119.163.218','18.205.109.152','114.119.164.173','114.119.160.139','114.119.167.117','66.249.70.20','114.119.166.190','114.119.165.26','207.46.13.173','207.46.13.48','157.55.39.230','114.119.166.244') )
0.000151 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '594'
0.000160 - SELECT * FROM bb_online WHERE (online_topic = '594' AND online_uid <> '0')
0.000276 - SELECT * FROM `users` WHERE uid IN (272,1)
0.000163 - SELECT * FROM bb_online WHERE online_uid IN (272,1)
0.000183 - SELECT groupid FROM groups_users_link WHERE uid=272
0.000203 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 19 AND rank_max >= 19 AND rank_special = 0
0.000052 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000050 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 7
Total: 48
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 7014880 bytes
XOOPS a mis 0.078 seconde(s) pour charger
Module display a mis 0.007 seconde(s) pour charger
