83 Personne(s) en ligne (82 Personne(s) connectée(s) sur Forum)
Invité(s): 83
Adapter des poignées intérieurs de phase 2 sur phase 1
De 92
Post(s): 387
Bonjour à tous, je voulais savoir si il était possible d'adapter des poignées d'ouverture de porte intérieur de phase 2 sur phase 1, car il me semble que les formes sont très légèrement différentes, je voudrais adapter les coques ainsi que les poignées.
Contribution le : 03/03/2009 20:15
0.000107 - SET NAMES 'utf8'
0.000647 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.006262 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '64f4e01e0e56c656204c0b130366ee28'
0.000209 - SELECT * FROM modules WHERE dirname = 'newbb'
0.001869 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000525 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000232 - SELECT * FROM bb_topics WHERE topic_id=9706
0.000125 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000742 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000794 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000967 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000392 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 9706
0.000100 - SELECT * FROM bb_topics WHERE topic_id=9706
0.000177 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=9706 AND approved = 1
0.000206 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=9706 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000168 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =9706
0.000218 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000834 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000439 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000242 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000633 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000164 - SELECT * FROM groups
0.000260 - SELECT * FROM bb_forums ORDER BY forum_order
0.000178 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000285 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000174 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.191.195.110'
0.000118 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1713452955, '18.191.195.110', 5)
0.000136 - SELECT * FROM online
0.000101 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000203 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.191.195.110'
0.000095 - UPDATE online SET online_updated=1713452955, online_module = 5 WHERE online_uid = 0 AND online_ip='18.191.195.110'
0.000173 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.191.195.110'
0.000080 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1713452955, '18.191.195.110', 6, 9706)
0.000121 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000824 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('111.225.148.239','185.191.171.8','47.128.32.180','111.225.149.103','85.208.96.203','40.77.167.63','110.249.201.83','54.36.148.193','54.36.148.239','110.249.202.84','54.36.149.33','54.36.149.95','110.249.202.73','54.36.149.100','18.191.195.110','85.208.98.20','52.167.144.25','54.36.148.153','185.191.171.2','54.36.148.68','85.208.96.210','54.36.148.40','85.208.96.207','185.191.171.3','54.36.148.142','85.208.98.19','54.36.149.92','54.36.148.76','54.36.148.163','144.76.23.213','85.208.98.24','185.191.171.7','47.128.32.170','47.128.99.60','54.36.148.212','3.145.191.169','54.36.148.130','54.36.148.52','54.36.149.86','85.208.96.208','110.249.201.140','54.36.148.183','54.36.148.237','47.128.32.19','54.36.148.9','85.208.98.29','185.191.171.6','85.208.98.22','111.225.149.131','54.36.149.65','54.36.149.48','54.36.149.2','3.93.194.100','54.36.148.174','54.36.148.134','185.191.171.5','54.36.148.145','54.36.148.92','54.36.148.112','54.36.149.29','52.14.150.55','54.36.148.160','54.36.148.121','85.208.96.195','185.191.171.9','54.36.149.98','85.208.96.205','110.249.202.209','54.36.149.1','54.36.148.151','54.36.148.192','111.225.149.191','44.221.73.249','54.36.148.181','110.249.202.69','185.191.171.12','185.191.171.13','54.36.149.11','52.167.144.198','54.36.148.186','54.92.219.193','110.249.202.85') )
0.000122 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '9706'
0.000103 - SELECT * FROM bb_online WHERE (online_topic = '9706' AND online_uid <> '0')
0.000171 - SELECT * FROM `users` WHERE uid IN (2566)
0.000097 - SELECT * FROM bb_online WHERE online_uid IN (2566)
0.000156 - SELECT groupid FROM groups_users_link WHERE uid=2566
0.000108 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000114 - SELECT * FROM smiles
0.000157 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000134 - SELECT post_id FROM bb_posts WHERE topic_id = 9706 AND pid = 0
0.000300 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 46
Usage de la mémoire: 7986384 bytes
XOOPS a mis 0.417 seconde(s) pour charger
Module display a mis 0.015 seconde(s) pour charger
Page rendering a mis 0.319 seconde(s) pour charger
