Fatal error: Call to undefined function mb_convert_encoding() in /home/frracing/public_html/ludo/www/xoops/class/module.textsanitizer.php on line 517
Aucun Tout Erreur(s) (10) Deprécié(s) (38) Requête(s) (46) Bloc(s) (5) Extra (2) Temporisation(5)
0.000191 - SET NAMES 'utf8'
0.000129 - SET SQL_BIG_SELECTS = 1
0.000319 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'af459f9588c9b95609d9452ed4b172bb'
0.000092 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000124 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000293 - DELETE FROM protector_access WHERE expire < UNIX_TIMESTAMP()
0.000356 - SELECT COUNT(*) FROM protector_access WHERE ip='3.226.245.48' AND request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=998'
0.000230 - SELECT COUNT(*) FROM protector_access WHERE ip='3.226.245.48'
0.000133 - INSERT INTO protector_access SET ip='3.226.245.48',request_uri='/xoops/modules/newbb/viewtopic.php?topic_id=998',expire=UNIX_TIMESTAMP()+'60'
0.000169 - SELECT * FROM bb_topics WHERE topic_id=998
0.000192 - SELECT * FROM bb_forums WHERE forum_id = 6
0.000083 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000091 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001141 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000254 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 998
0.000119 - SELECT * FROM bb_topics WHERE topic_id=998
0.000278 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=998 AND approved = 1
0.000311 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=998 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000195 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =998
0.000128 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000051 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000087 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000301 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.226.245.48'
0.000284 - UPDATE online SET online_updated=1597182125, online_module = 5 WHERE online_uid = 0 AND online_ip='3.226.245.48'
0.000196 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='3.226.245.48'
0.000160 - UPDATE online SET online_updated=1597182125, online_module = 5 WHERE online_uid = 0 AND online_ip='3.226.245.48'
0.000197 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='3.226.245.48'
0.000143 - UPDATE bb_online SET online_updated= '1597182125', online_forum = '6', online_topic = '998' WHERE online_uid = 0 AND online_ip='3.226.245.48'
0.000283 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('114.119.164.173','114.119.160.139','114.119.166.190','114.119.163.218','63.143.42.253','114.119.164.234','114.119.165.26','114.119.166.165','114.119.167.117','40.77.167.240','40.77.167.241','157.55.39.222','185.25.35.14','40.77.167.68','207.46.13.51','3.226.245.48','114.119.166.244','114.119.167.169') )
0.000110 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '998'
0.000123 - SELECT * FROM bb_online WHERE (online_topic = '998' AND online_uid <> '0')
0.000200 - SELECT * FROM `users` WHERE uid IN (445)
0.000168 - SELECT * FROM bb_online WHERE online_uid IN (445)
0.000204 - SELECT groupid FROM groups_users_link WHERE uid=445
0.000206 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 293 AND rank_max >= 293 AND rank_special = 0
Total: 46
Fichier(s) inclu(s): 116 fichier(s)
Usage de la mémoire: 6866632 bytes
XOOPS a mis 0.074 seconde(s) pour charger
XOOPS output init a mis 0.031 seconde(s) pour charger
Module display a mis 0.006 seconde(s) pour charger
