38 Personne(s) en ligne (34 Personne(s) connectée(s) sur Forum)
Invité(s): 38
autoradio 2 din
De 54
Post(s): 218
Bonjours a tous je souhaiterais savoire si quelqu un aurai poser un autoradio 2 din
Contribution le : 30/08/2008 15:25
Re: autoradio 2 din
Post(s): 594
je ne pence pas que se soit possible, a- de faire dénorme modif sur le TDB
Contribution le : 31/08/2008 14:45
Re: autoradio 2 din
+1 !!! Sauf si tu veux déplacer je ne sais pas ou ta console de commande de chauffage, mais je doute que ce soit si simple que ça !!!
Contribution le : 31/08/2008 15:04
0.000072 - SET NAMES 'utf8'
0.000508 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000177 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '213188e5ddbedd196f4381c20e4d37ce'
0.000199 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002114 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000579 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000245 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 133787
0.000205 - SELECT * FROM bb_forums WHERE forum_id = 6
0.001034 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000960 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.001015 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '6' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000176 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 8313
0.000091 - SELECT * FROM bb_topics WHERE topic_id=8313
0.000157 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=8313 AND approved = 1
0.000144 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=8313 AND approved = 1 AND post_id < 133787
0.000222 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=8313 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000187 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =8313
0.000246 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000992 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000455 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000213 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000839 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000119 - SELECT * FROM groups
0.000281 - SELECT * FROM bb_forums ORDER BY forum_order
0.000189 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000280 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000189 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.116.239.195'
0.000116 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714222112, '18.116.239.195', 5)
0.000144 - SELECT * FROM online
0.000107 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000191 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.116.239.195'
0.000105 - UPDATE online SET online_updated=1714222112, online_module = 5 WHERE online_uid = 0 AND online_ip='18.116.239.195'
0.000114 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.116.239.195'
0.000119 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714222112, '18.116.239.195', 6, 8313)
0.000121 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000352 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('54.36.148.11','54.36.148.156','54.36.148.81','54.36.148.137','111.225.148.113','54.36.148.205','54.36.148.113','54.36.148.55','54.36.148.204','45.196.54.250','3.14.142.115','3.138.125.2','18.221.141.44','110.249.202.148','54.36.148.114','54.36.148.245','54.36.148.57','54.36.148.26','54.36.148.95','18.191.236.174','110.249.201.84','3.135.246.193','18.116.239.195','13.59.61.119','110.249.201.5','157.55.39.57','40.77.167.45','52.167.144.221','54.36.149.69','54.36.148.23','111.225.148.236','54.36.148.96','18.218.172.249','192.53.69.185') )
0.000101 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '8313'
0.000098 - SELECT * FROM bb_online WHERE (online_topic = '8313' AND online_uid <> '0')
0.000273 - SELECT * FROM `users` WHERE uid IN (2455,1032,1779)
0.000121 - SELECT * FROM bb_online WHERE online_uid IN (2455,1032,1779)
0.000161 - SELECT groupid FROM groups_users_link WHERE uid=2455
0.000110 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000095 - SELECT * FROM smiles
0.000176 - SELECT groupid FROM groups_users_link WHERE uid=1032
0.000141 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 594 AND rank_max >= 594 AND rank_special = 0
0.000139 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000075 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000141 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000142 - SELECT post_id FROM bb_posts WHERE topic_id = 8313 AND pid = 0
0.000356 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8231992 bytes
XOOPS a mis 0.244 seconde(s) pour charger
XOOPS output init a mis 0.112 seconde(s) pour charger
