176 Personne(s) en ligne (133 Personne(s) connectée(s) sur Forum)
Invité(s): 176
« 1 (2)
Re: [ 2L16s F7R ] sonde température LDR
ah ok , je pensais que c'était les produits d'origine sur oscaro .
Contribution le : 17/06/2011 16:55
voici les prix actualisé des sondes :
7700829427 28.35€ HT
7700865290 27.42€ HT
Soit 66.70€ TTC.
Contribution le : 21/06/2011 07:41
« 1 (2)
0.000117 - SET NAMES 'utf8'
0.001056 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0025a4b062117fdd48f687d4f6bcb645'
0.000329 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 289786
0.000059 - SELECT * FROM bb_forums WHERE forum_id = 9
0.000032 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '9' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000618 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 14688
0.000121 - SELECT * FROM bb_topics WHERE topic_id=14688
0.000035 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14688 AND approved = 1
0.000472 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=14688 AND approved = 1 AND post_id < 289786
0.000054 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=14688 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000418 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =14688
0.000498 - SELECT * FROM bb_forums ORDER BY forum_order
0.000034 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000273 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000512 - UPDATE online SET online_updated=1789927373, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000623 - SELECT * FROM online
0.000620 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000092 - -300
0.000191 - DELETE FROM online WHERE online_updated < 1789927073
0.000190 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000224 - UPDATE online SET online_updated=1789927373, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000140 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000255 - UPDATE bb_online SET online_updated= '1789927373', online_forum = '9', online_topic = '14688' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.001362 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('173.211.15.21','45.58.211.17','217.8.218.156','189.84.176.76','136.112.32.154','136.65.206.196','185.191.171.9','52.167.144.169','35.202.223.123','35.254.25.136','136.65.144.175','34.67.235.108','35.254.201.217','34.71.243.182','136.114.190.91','136.113.248.41','85.208.96.211','34.133.150.125','35.188.212.31','34.136.50.121','34.41.18.53','35.223.180.90','34.132.30.84','35.225.92.119','136.113.250.234','136.114.251.171','64.224.107.74','35.255.139.26','136.115.95.158','136.112.169.254','74.123.105.229','172.59.195.104','136.119.145.242','34.44.114.244','34.30.142.93','34.133.64.91','34.134.224.139','34.173.48.161','66.249.68.193','85.208.96.199','216.73.217.83','34.31.95.75','35.254.195.237','136.116.59.242','34.67.133.93','85.208.96.194','136.119.87.190','35.202.11.48','34.27.43.36','34.30.52.134','24.1.146.167','34.9.203.105','34.66.45.93','160.19.93.84','34.9.180.63','104.198.16.217','35.226.106.205','34.10.84.36','35.239.248.73','34.30.233.192','35.226.87.141','34.123.129.208','116.206.88.252','34.57.28.101','34.59.183.133','144.76.23.207','35.226.113.131','35.192.131.166','34.135.47.220','104.197.166.106','35.193.15.59','34.56.146.15','34.61.77.59','146.148.110.159','34.29.186.28','35.193.156.72','34.27.103.20','185.97.92.127','34.10.194.123','136.64.93.95','34.44.229.100','136.115.0.150','35.255.247.90','35.238.73.253','34.28.137.40','34.61.148.235','35.222.47.18','185.138.234.156','34.27.5.65','34.29.77.190','34.55.37.33','35.194.37.141','34.172.179.139','85.208.96.200','34.27.99.191','34.122.252.130','66.249.68.192','217.22.255.138','34.173.138.43','104.198.177.225','34.133.237.161','34.135.98.122','34.135.220.83','185.191.171.4','45.38.171.250','170.78.249.238','186.19.22.98','34.72.19.252','34.44.249.127','35.193.255.230','34.132.249.233','136.114.7.39','136.111.70.61','35.225.182.77','35.184.81.141','154.28.239.165','66.249.79.3','66.249.68.194','34.9.131.229','122.201.22.73','35.222.231.60','35.184.42.130','136.119.214.88','34.132.16.45','136.115.98.185','85.208.96.193','35.254.55.111','34.10.138.17','34.45.53.200','34.29.246.143','185.191.171.18','34.31.108.231','176.163.252.123') )
0.000202 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '14688'
0.000283 - SELECT * FROM bb_online WHERE (online_topic = '14688' AND online_uid <> '0')
0.000078 - SELECT * FROM `users` WHERE uid IN (3740,21)
0.000125 - SELECT * FROM bb_online WHERE online_uid IN (3740,21)
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3740
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1162 AND rank_max >= 1162 AND rank_special = 0
0.000049 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000075 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000055 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000023 - SELECT post_id FROM bb_posts WHERE topic_id = 14688 AND pid = 0
0.001056 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8164792 bytes
