201 Personne(s) en ligne (185 Personne(s) connectée(s) sur Forum)
Invité(s): 201
Post(s): 316
Non, celle ci
isotak a écrit:
Post(s): 590
Le poid,c est l ennemie...
Réponse en image !
Post(s): 316
il a l'air plus lisse non ?
ShInGiN a écrit:
Oui faut etre bien motivé...
Donc voila en photo
Et une fois intégré !
C'est bien intégrer comme ca.
De Nord
Post(s): 650
A bientôt.
FAB.
FAB alias Aspec
Clio...., Megane 3 RS
TOP
Merci les gars!
Post(s): 590
0.000137 - SET NAMES 'utf8'
0.000115 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001279 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'a408a35acb2a8e92cd71644be348fdab'
0.000032 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.001436 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 357152
0.000052 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000161 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000332 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000190 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.006533 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1 AND post_id < 357152
0.015062 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 1890, 30
0.000727 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000168 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000128 - SELECT * FROM groups
0.000208 - SELECT * FROM bb_forums ORDER BY forum_order
0.000285 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000726 - UPDATE online SET online_updated=1792769674, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000443 - SELECT * FROM online
0.000220 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000379 - UPDATE online SET online_updated=1792769674, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000200 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000805 - UPDATE bb_online SET online_updated= '1792769674', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000321 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.002733 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('172.121.96.55','172.121.38.207','72.63.72.149','83.57.173.21','192.177.93.184','189.81.4.198','46.1.28.27','87.196.16.241','122.168.6.82','27.58.153.171','78.175.230.61','42.117.48.188','46.153.117.129','83.120.60.10','45.38.33.166','79.106.215.59','189.81.2.76','5.36.241.85','192.145.68.239','196.210.226.232','179.64.71.242','176.205.254.151','185.191.171.14','45.94.217.9','185.191.171.1','169.224.8.231','179.0.107.149','2.180.138.172','187.249.110.148','185.191.171.16','78.176.253.47','85.208.96.196','181.97.5.51','112.207.106.136','197.186.67.84','117.207.238.119','94.254.128.63','64.52.27.163','185.189.209.80','185.191.171.3','66.249.69.67','74.7.241.29','185.191.171.10','85.208.96.198','95.26.49.199','102.213.106.228','166.114.131.64','189.81.71.28','188.251.90.145','207.32.139.223','179.125.145.53','41.10.89.100','190.62.88.1','172.121.43.190','165.165.244.150','170.245.16.237','66.9.174.132','103.41.24.196','104.165.210.76','85.62.149.153','192.177.122.232','192.177.105.245','86.245.222.59','39.58.154.176','179.155.120.95','187.40.45.81','85.208.96.202','88.99.95.199','91.146.89.211','95.219.26.181','200.151.110.171','168.140.243.254','170.83.223.27','176.20.211.225','174.140.218.86','216.73.217.110','5.34.4.55','194.77.192.180','72.50.7.248','200.63.106.204','213.230.86.116','81.9.194.130','82.86.130.77','204.77.7.134','41.90.136.255','166.114.142.250','41.214.3.229','79.117.145.106','188.64.11.20','220.181.108.94','207.32.135.221','84.247.40.194','172.121.254.104','188.52.208.182','138.97.217.189','180.153.197.52','89.237.201.75','201.25.175.6','168.181.239.39','195.81.117.26','185.191.171.2','207.32.153.97','104.165.161.125','139.100.132.134','187.112.86.82','40.77.167.41','84.44.124.245','40.77.167.30','191.102.139.93','106.206.226.23','105.66.134.197','88.243.139.202','64.52.24.15','146.120.162.254','104.50.251.60','185.191.171.13','188.214.9.83','143.105.233.232','46.185.190.81','185.191.171.19','192.177.122.146','182.8.122.208','37.254.50.44','177.38.244.174','186.182.91.8','190.93.2.12','104.253.160.233','104.253.130.249','213.200.31.207','82.197.48.229','91.241.218.2','176.88.166.220','194.44.57.127','207.32.153.211','168.227.54.42','5.29.10.85','190.148.14.250','85.208.96.200','187.188.243.147','196.217.137.195','189.81.5.8','185.191.171.12','85.208.96.207','169.224.17.161','176.96.249.55','192.141.114.154','207.32.156.36','178.220.61.114','91.49.109.196','176.28.148.22','87.116.165.197','90.48.233.147','168.222.51.72','172.252.127.116','102.213.48.173','102.219.243.118','185.171.147.174','172.121.96.111','180.191.125.158','93.114.210.205','189.81.3.128','167.62.213.192','185.191.171.4','190.137.13.45','103.254.167.105','105.71.18.220','186.194.12.225','85.208.96.205','190.128.236.2','203.89.97.75','139.5.1.113','196.216.60.9','189.81.4.10','88.188.133.25','104.252.209.109','104.252.38.100','177.11.95.80','190.30.210.7','72.63.70.112','66.249.69.68','74.125.214.226','185.39.29.5','94.158.58.151','105.74.75.184','102.160.0.88') )
0.000265 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000169 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.001105 - SELECT * FROM `users` WHERE uid IN (6934,1611,1315,4383,841,133,5,21,1804,4050,9887)
0.001317 - SELECT * FROM bb_online WHERE online_uid IN (6934,1611,1315,4383,841,133,5,21,1804,4050,9887)
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=6934
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 316 AND rank_max >= 316 AND rank_special = 0
0.000176 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1547 AND rank_max >= 1547 AND rank_special = 0
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=4383
0.000037 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000191 - SELECT groupid FROM groups_users_link WHERE uid=133
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 590 AND rank_max >= 590 AND rank_special = 0
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000035 - SELECT groupid FROM groups_users_link WHERE uid=1804
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 650 AND rank_max >= 650 AND rank_special = 0
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=4050
0.000038 - SELECT groupid FROM groups_users_link WHERE uid=9887
0.000087 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000037 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
Total: 67
Usage de la mémoire: 10220728 bytes
XOOPS a mis 0.379 seconde(s) pour charger
Module init a mis 0.042 seconde(s) pour charger
Page rendering a mis 0.206 seconde(s) pour charger
