101 Personne(s) en ligne (60 Personne(s) connectée(s) sur Forum)
Invité(s): 101
probleme photo avatar
Post(s): 16
hello,
J'ai un petit soucis je n'arrive pas a mettre un avatar sur mon profil, comme indiquer dans la FAC je vais dans mon profil section avatar mais sa me met just choisir un avatar dans la liste... mais je n'en es pas dans la liste, comment faire? merci bien
Contribution le : 16/08/2014 08:08
Re: probleme photo avatar
Il faut que tu upload une photo de 130 x130 max il me semble pour que tu puisse ensuite la mettre
Contribution le : 16/08/2014 10:54
Post(s): 16
nikel sayais jai reussi
Contribution le : 16/08/2014 11:02
0.000204 - SET NAMES 'utf8'
0.000055 - SET SQL_BIG_SELECTS = 1
0.001327 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'cd8431181b43a6c966b81d36212ae9fc'
0.000152 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000381 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 360299
0.000062 - SELECT * FROM bb_forums WHERE forum_id = 4
0.000060 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000116 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '4' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000294 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 19028
0.000157 - SELECT * FROM bb_topics WHERE topic_id=19028
0.000250 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19028 AND approved = 1
0.000287 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19028 AND approved = 1 AND post_id < 360299
0.000377 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=19028 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000219 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =19028
0.000086 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000113 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000226 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000133 - UPDATE online SET online_updated=1793907422, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000360 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.025118 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000278 - UPDATE online SET online_updated=1793907422, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000214 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000251 - UPDATE bb_online SET online_updated= '1793907422', online_forum = '4', online_topic = '19028' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000313 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001011 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('108.6.148.69','144.76.23.194','171.252.225.175','168.167.18.189','51.174.15.124','193.104.126.69','206.180.143.95','85.208.96.211','93.170.185.63','185.191.171.19','45.225.91.109','185.191.171.11','113.19.183.24','41.50.57.29','157.55.39.205','102.208.120.145','5.183.255.39','179.6.23.166','202.46.61.111','80.217.238.224','66.249.70.192','188.22.100.251','103.72.190.198','89.147.166.138','83.167.40.95','170.168.29.55','102.223.157.229','40.77.167.24','31.134.2.41','85.208.96.205','39.101.88.165','186.169.63.72','216.73.216.84','213.188.176.57','87.95.116.69','185.191.171.6','196.238.106.114','185.191.171.14','66.249.64.8','50.117.107.184','185.191.171.12','80.68.109.42','87.241.158.243','185.191.171.2','69.94.45.234','186.179.68.20','62.217.141.166','31.134.7.68','188.167.251.243','185.191.171.16','86.15.111.84','196.115.25.161','190.122.176.6','178.51.137.190','185.191.171.10','216.234.223.110','173.34.128.251','85.117.228.153','74.125.210.196','185.191.171.13') )
0.000229 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '19028'
0.000218 - SELECT * FROM bb_online WHERE (online_topic = '19028' AND online_uid <> '0')
0.000339 - SELECT * FROM `users` WHERE uid IN (11111,2633)
0.000171 - SELECT * FROM bb_online WHERE online_uid IN (11111,2633)
0.000174 - SELECT groupid FROM groups_users_link WHERE uid=11111
0.000038 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 16 AND rank_max >= 16 AND rank_special = 0
0.000067 - SELECT * FROM bb_categories WHERE cat_id = 2
0.000203 - SELECT post_id FROM bb_posts WHERE topic_id = 19028 AND pid = 0
Total: 49
Usage de la mémoire: 8174832 bytes
XOOPS a mis 0.269 seconde(s) pour charger
Module init a mis 0.062 seconde(s) pour charger
Page rendering a mis 0.078 seconde(s) pour charger
