90 Personne(s) en ligne (68 Personne(s) connectée(s) sur Forum)
Invité(s): 90
Photo tambour coloré
Post(s): 11
Salut a tous,
J'aimerai peindre mes tambour arriere en rouge sur ma megane bleu nuit mais je ne sais pas leffet que cela donne:)
Certain d'entre vous on t'il des photos ?
Contribution le : 17/03/2015 10:32
Re: Photo tambour coloré
De Antibes
Post(s): 1350
comme ça , ça dépend si les jantes couvre beaucoup ou non
avec les jantes d'origine des 1.6 16v on voit quasi rien
Contribution le : 20/03/2015 18:32
0.000119 - SET NAMES 'utf8'
0.001034 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'fc863eee9f2aa256e8c92efa13cfc82c'
0.000285 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000331 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 366261
0.000060 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000070 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000322 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 19440
0.000101 - SELECT * FROM bb_topics WHERE topic_id=19440
0.000179 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19440 AND approved = 1
0.000148 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19440 AND approved = 1 AND post_id < 366261
0.000232 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=19440 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000228 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =19440
0.000164 - DELETE FROM online WHERE online_updated < 1793906610
0.000290 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000115 - UPDATE online SET online_updated=1793906910, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000208 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000240 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000139 - UPDATE online SET online_updated=1793906910, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000185 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000153 - UPDATE bb_online SET online_updated= '1793906910', online_forum = '5', online_topic = '19440' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000207 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000709 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.9','31.134.14.81','180.148.4.209','45.164.32.143','201.225.243.189','103.185.25.11','41.109.60.196','162.220.96.239','85.208.96.205','147.235.197.197','85.208.96.206','190.183.19.63','168.232.225.233','108.6.148.69','85.208.96.195','188.241.101.242','89.85.202.97','124.29.247.114','79.243.120.222','31.36.227.51','95.10.239.105','177.47.169.42','86.234.162.3','66.249.64.6','193.142.38.251','85.208.96.209','109.81.90.50','186.22.245.4','202.157.191.196','90.129.203.31','92.176.148.62','195.81.117.250','138.97.160.107','216.73.216.84','197.234.87.219','78.82.191.68','92.97.109.139','93.107.124.245','84.122.229.149','92.209.238.65','186.52.200.243','95.215.106.232','92.109.217.123','141.98.141.220','217.62.192.189','206.85.1.113','190.5.45.240','81.204.188.244','93.112.204.125','185.191.171.16','78.48.16.235','37.179.94.54','85.208.96.210','179.191.237.11','95.5.70.51','109.92.158.14','62.233.39.56','154.20.48.227','186.179.68.20','185.229.54.167','213.188.176.57','82.215.102.88','45.167.1.27','104.165.197.43','31.105.108.243','167.250.133.91','192.101.65.13','85.208.96.200') )
0.000166 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '19440'
0.000490 - SELECT * FROM bb_online WHERE (online_topic = '19440' AND online_uid <> '0')
0.000281 - SELECT * FROM `users` WHERE uid IN (11183,4834)
0.000125 - SELECT * FROM bb_online WHERE online_uid IN (11183,4834)
0.000175 - SELECT groupid FROM groups_users_link WHERE uid=11183
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 11 AND rank_max >= 11 AND rank_special = 0
0.000031 - SELECT groupid FROM groups_users_link WHERE uid=4834
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1350 AND rank_max >= 1350 AND rank_special = 0
0.000172 - SELECT post_id FROM bb_posts WHERE topic_id = 19440 AND pid = 0
Total: 50
Usage de la mémoire: 8108928 bytes
XOOPS a mis 0.156 seconde(s) pour charger
