129 Personne(s) en ligne (95 Personne(s) connectée(s) sur Forum)
Invité(s): 129
Volant
Post(s): 10
Bonjour auriez vous une astuce pour renover un volant en cuir qui s'effrite sans le changer merci (je l'ai bien nettoyer a l'eau chaude et aplliquer de l'huile de pied de boeuf mais aucun changement)
Contribution le : 13/08/2015 21:19
Re: Volant
Sujet déplacé.
Pas de miracle, le cuir s'effrite, donc à part le poncer légèrement pour applanir la surface, rien à faire sans passer par la case changement...
Contribution le : 14/08/2015 09:03
0.000126 - SET NAMES 'utf8'
0.000862 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'fd4cd7c8bd69e960e71707c63c1a3f15'
0.000268 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 369582
0.000069 - SELECT * FROM bb_forums WHERE forum_id = 30
0.000067 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '30' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000254 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 19728
0.000102 - SELECT * FROM bb_topics WHERE topic_id=19728
0.000177 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19728 AND approved = 1
0.000450 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19728 AND approved = 1 AND post_id < 369582
0.000380 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=19728 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000178 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =19728
0.000500 - DELETE FROM online WHERE online_updated < 1793909456
0.000173 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000371 - UPDATE online SET online_updated=1793909756, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000203 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000303 - UPDATE online SET online_updated=1793909756, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000454 - UPDATE bb_online SET online_updated= '1793909756', online_forum = '30', online_topic = '19728' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000950 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('79.126.113.226','134.249.12.43','81.107.233.148','85.208.96.211','178.165.183.57','85.208.96.199','185.191.171.19','41.90.145.229','47.185.161.5','176.140.68.217','185.191.171.5','31.134.13.169','66.249.70.202','46.128.8.6','85.208.96.210','93.186.72.243','86.108.22.32','45.224.98.209','213.74.43.238','14.180.31.5','212.237.122.181','85.208.96.198','102.100.162.122','212.70.99.192','105.186.231.116','38.252.48.53','187.62.85.75','186.29.52.91','190.109.22.234','187.84.241.112','223.123.118.247','45.145.132.1','196.179.30.174','85.208.96.197','104.164.54.197','185.191.171.14','167.253.18.109','195.81.148.212','212.159.165.209','122.8.47.151','85.208.96.195','178.115.91.172','195.81.191.106','186.94.147.99','189.178.6.81','38.46.247.87','90.233.195.169','85.208.96.207','27.79.121.243','87.241.157.54','130.49.114.247','31.134.4.161','196.75.204.67','102.206.159.84','143.44.146.127','185.191.171.3','181.132.130.172','38.210.164.113','118.161.99.51','185.191.171.13','90.242.195.220','95.184.78.90','151.177.104.88','82.24.210.183','185.147.100.233','41.248.127.184','216.73.216.244','51.175.158.185','105.27.128.74','87.49.45.157','213.217.205.123','184.163.63.195','196.190.132.66','157.55.39.7','91.82.240.128','85.208.96.196','88.244.103.134','157.100.137.225','179.63.191.100','179.6.23.203','94.249.49.68','201.4.71.213','152.232.247.173','40.77.167.235','85.208.96.206','190.99.23.153','102.38.1.172','155.133.78.47','73.149.160.222','64.67.107.176','66.249.70.192','45.176.235.213','85.81.42.41','79.106.215.227','103.181.127.136') )
0.000176 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '19728'
0.000174 - SELECT * FROM bb_online WHERE (online_topic = '19728' AND online_uid <> '0')
0.000306 - SELECT * FROM `users` WHERE uid IN (26280,1779)
0.000124 - SELECT * FROM bb_online WHERE online_uid IN (26280,1779)
0.000206 - SELECT groupid FROM groups_users_link WHERE uid=26280
0.000029 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 10 AND rank_max >= 10 AND rank_special = 0
0.000038 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000219 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000307 - SELECT post_id FROM bb_posts WHERE topic_id = 19728 AND pid = 0
Usage de la mémoire: 8130520 bytes
XOOPS a mis 0.108 seconde(s) pour charger
Page rendering a mis 0.014 seconde(s) pour charger
