91 Personne(s) en ligne (61 Personne(s) connectée(s) sur Forum)
Invité(s): 91
 Bas   Précédent   Suivant  Le sujet est verrouillé
quel kit éclaté focal?
De vienne isere
Post(s): 372
Bonjour, j'aimerai changer le kit éclaté d'origine par un focal. Je voudrais savoir quel serait le meilleur kit éclaté sachant que la source est un autoradio alpine(me souviens plus du model) et que je ne veux pas amplifier le kit. Merci a tous
Contribution le : 01/09/2015 10:30
Re: quel kit éclaté focal?
merci de continuer a la suite de ton sujet juste en dessous.
Contribution le : 01/09/2015 11:40
0.000148 - SET NAMES 'utf8'
0.000357 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0d099c2b11f3b91cc53a429bb41110fe'
0.000366 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 369840
0.000070 - SELECT * FROM bb_forums WHERE forum_id = 7
0.000040 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '7' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000357 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 19750
0.000141 - SELECT * FROM bb_topics WHERE topic_id=19750
0.000240 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19750 AND approved = 1
0.000195 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=19750 AND approved = 1 AND post_id < 369840
0.000267 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=19750 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.002828 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =19750
0.000063 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000658 - SELECT * FROM groups
0.000262 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000886 - UPDATE online SET online_updated=1793907313, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000252 - SELECT * FROM online
0.000262 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000222 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000591 - UPDATE online SET online_updated=1793907313, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000176 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000918 - UPDATE bb_online SET online_updated= '1793907313', online_forum = '7', online_topic = '19750' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000663 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('128.127.120.23','193.203.9.68','168.167.18.189','51.174.15.124','193.104.126.69','206.180.143.95','85.208.96.211','93.170.185.63','185.191.171.19','45.225.91.109','185.191.171.11','45.148.234.27','113.19.183.24','41.50.57.29','157.55.39.205','102.208.120.145','5.183.255.39','179.6.23.166','202.46.61.111','80.217.238.224','66.249.70.192','196.207.235.29','188.212.135.222','85.208.96.203','2.214.61.184','102.223.157.229','40.77.167.24','31.134.2.41','85.208.96.205','143.59.216.8','186.169.63.72','216.73.216.84','90.35.59.72','185.191.171.6','154.27.132.130','50.117.107.184','185.191.171.12','80.68.109.42','190.61.114.243','185.191.171.2','92.109.217.123','186.179.68.20','62.217.141.166','190.104.106.69','31.134.7.68','188.167.251.243','217.136.89.251','185.191.171.18','217.39.51.218','27.114.151.78','147.235.197.197','178.51.137.190','85.208.96.210','185.191.171.10','216.234.223.110','173.34.128.251','85.117.228.153','74.125.210.196','66.249.70.202','185.191.171.13','185.171.61.64') )
0.000189 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '19750'
0.000171 - SELECT * FROM bb_online WHERE (online_topic = '19750' AND online_uid <> '0')
0.000386 - SELECT * FROM `users` WHERE uid IN (4584,21)
0.000164 - SELECT * FROM bb_online WHERE online_uid IN (4584,21)
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=4584
0.000042 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 9
0.000056 - SELECT groupid FROM groups_users_link WHERE uid=21
0.000056 - SELECT * FROM bb_categories WHERE cat_id = 3
Total: 47
Fichier(s) inclu(s): 135 fichier(s)
Usage de la mémoire: 6950936 bytes
Module init a mis 0.063 seconde(s) pour charger
