215 Personne(s) en ligne (150 Personne(s) connectée(s) sur Forum)
Invité(s): 215
« 1 (2)
Re: vidange boite==> nfj ou nfp?
Post(s): 5
c'est pas simple...
dans le manuel d'origine,il est indiqué TRX, désormais remplacé par la NFP, jusque la tout va bien.
sauf que:
http://www.lubadmin.com/upload/produit/FichePDF/lang_1/7195.pdf
http://www.lubadmin.com/upload/produit/fichepdf/lang_5/1075.pdf
pffffffffff
Contribution le : 17/09/2016 07:13
« 1 (2)
0.000091 - SET NAMES 'utf8'
0.000939 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '15eaeeec90e2f748a9e6ba43c85ae601'
0.000284 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 374815
0.000087 - SELECT * FROM bb_forums WHERE forum_id = 9
0.000065 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '9' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000353 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10861
0.000586 - SELECT * FROM bb_topics WHERE topic_id=10861
0.001350 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10861 AND approved = 1
0.000260 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10861 AND approved = 1 AND post_id < 374815
0.001264 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10861 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000445 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =10861
0.000267 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000118 - UPDATE online SET online_updated=1792638454, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000377 - SELECT * FROM online
0.000501 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000180 - UPDATE online SET online_updated=1792638455, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000178 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000136 - UPDATE bb_online SET online_updated= '1792638455', online_forum = '9', online_topic = '10861' WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000281 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001260 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('187.40.209.218','138.122.83.156','201.159.76.151','43.173.177.88','43.173.177.117','43.173.176.209','139.47.126.122','209.166.24.37','94.157.64.118','188.81.145.98','93.70.85.180','190.206.105.252','192.178.7.65','185.191.171.9','190.5.42.17','196.115.220.101','77.40.94.192','5.188.66.35','91.49.118.60','75.159.157.135','160.187.57.213','177.92.146.27','205.188.173.33','43.173.182.222','179.189.43.229','201.14.251.235','181.99.105.92','85.208.96.199','205.188.173.82','79.177.141.179','43.173.181.189','64.57.129.29','187.95.223.151','190.11.80.167','201.14.244.79','136.36.87.151','85.254.180.141','119.8.181.38','85.208.96.210','72.238.157.29','149.90.27.147','84.124.219.5','205.188.172.85','200.196.40.81','177.53.215.9','108.17.94.91','86.38.118.203','189.37.65.208','43.173.180.74','37.53.233.254','152.136.25.43','212.124.7.110','83.167.40.95','27.147.200.102','50.72.197.23','23.230.136.142','220.181.108.103','201.14.244.189','91.254.115.29','72.63.191.70','147.235.199.137','176.137.71.43','31.42.230.163','160.176.38.59','43.173.178.56','43.173.173.41','43.172.194.245','48.47.30.90','84.46.183.231','186.14.0.249','93.183.131.128','176.131.187.103','43.172.197.71','48.47.9.72','48.47.9.187','88.174.209.75','187.209.90.213','49.176.106.190','153.52.219.219','201.24.174.178','179.209.45.130','61.6.249.86','118.200.67.49','87.232.201.209','85.208.96.200','45.92.238.134','79.42.161.248','186.78.116.29','181.209.95.86','73.217.165.223','71.227.120.187','209.166.7.215','172.59.29.172','23.230.123.130','91.235.56.65','23.230.136.24','77.228.125.240','31.98.28.6','45.38.238.181','193.188.252.230','186.52.130.255','95.13.124.15','191.15.29.187','181.46.136.15','69.91.188.185','216.73.216.171','86.38.123.29','72.27.41.45','47.41.165.68','179.60.93.182','43.172.195.160','86.38.118.85','112.65.211.71','41.249.56.185','192.116.46.31','179.190.163.71','71.239.82.236','5.29.15.173','185.191.171.18','87.171.41.144','174.165.181.11','85.208.96.203','131.0.35.34','72.63.126.25','72.63.125.253','52.167.144.166','185.191.171.4','213.230.78.0','43.173.176.125','189.103.183.2','105.156.223.213','85.208.96.195','170.100.128.96','142.127.7.54','192.104.181.254','39.34.141.71','184.152.165.191','153.52.220.114','138.94.179.245','37.107.7.154','72.63.158.204','85.208.96.201','186.14.140.207','48.47.30.209','72.63.157.95','164.138.93.71','205.188.194.43','104.253.129.106','194.199.7.28','166.114.132.81') )
0.000207 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10861'
0.000237 - SELECT * FROM bb_online WHERE (online_topic = '10861' AND online_uid <> '0')
0.000244 - SELECT * FROM `users` WHERE uid IN (26805)
0.000136 - SELECT * FROM bb_online WHERE online_uid IN (26805)
0.000151 - SELECT groupid FROM groups_users_link WHERE uid=26805
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 5 AND rank_max >= 5 AND rank_special = 0
0.000363 - SELECT post_id FROM bb_posts WHERE topic_id = 10861 AND pid = 0
0.000118 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 47
Usage de la mémoire: 8023656 bytes
XOOPS a mis 0.265 seconde(s) pour charger
Page rendering a mis 0.153 seconde(s) pour charger
