29 Personne(s) en ligne (25 Personne(s) connectée(s) sur Forum)
Invité(s): 29
Liquide hydraulique
Post(s): 6
Bonjour à tous et toutes. Peut-on utiliser du LHM (Citroën) comme liquide hydraulique pour la pompe du capote?
Bien à vous!
Contribution le : 14/11/2016 21:28
Re: Liquide hydraulique
non
Contribution le : 19/11/2016 08:30
De Rennes
Post(s): 58
Lequel alors seb ?
Contribution le : 20/11/2016 16:34
bah ca faut demander aux cabistes mais surtout pas de lhm
Contribution le : 20/11/2016 20:58
Post(s): 6
Dommage ... merci pour vos réponses!
Contribution le : 25/11/2016 00:05
0.000183 - SET NAMES 'utf8'
0.000601 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.000126 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7119a647ae2eca5dc17bdb44104a8453'
0.000199 - SELECT * FROM modules WHERE dirname = 'newbb'
0.002132 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000496 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000245 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 375383
0.000171 - SELECT * FROM bb_forums WHERE forum_id = 1
0.000805 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000858 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000967 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '1' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000168 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20406
0.000086 - SELECT * FROM bb_topics WHERE topic_id=20406
0.000155 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20406 AND approved = 1
0.000144 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20406 AND approved = 1 AND post_id < 375383
0.000220 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20406 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000157 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20406
0.000241 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '3') ORDER BY conf_order ASC
0.000887 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000453 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000220 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000667 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000137 - SELECT * FROM groups
0.000283 - SELECT * FROM bb_forums ORDER BY forum_order
0.000173 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000257 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000183 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.116.62.45'
0.000107 - INSERT INTO online (online_uid, online_uname, online_updated, online_ip, online_module) VALUES (0, '', 1714231921, '18.116.62.45', 5)
0.000109 - SELECT * FROM online
0.000090 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000184 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='18.116.62.45'
0.000086 - UPDATE online SET online_updated=1714231921, online_module = 5 WHERE online_uid = 0 AND online_ip='18.116.62.45'
0.000112 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='18.116.62.45'
0.000078 - INSERT INTO bb_online (online_uid, online_uname, online_updated, online_ip, online_forum, online_topic) VALUES (0, '', 1714231921, '18.116.62.45', 1, 20406)
0.000107 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000277 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('18.222.121.170','54.36.149.102','54.36.149.86','18.116.62.45','3.143.218.146','3.129.67.26','110.249.202.91','52.167.144.203','3.144.77.71','18.222.120.133','54.36.148.47','110.249.201.202','13.59.100.42','110.249.202.205','18.118.164.151','3.14.6.194','3.14.253.221','54.36.149.66','66.249.64.39','3.145.131.238','144.76.23.204','157.55.39.52','110.249.202.177','54.36.149.50','54.36.149.67') )
0.000099 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20406'
0.000105 - SELECT * FROM bb_online WHERE (online_topic = '20406' AND online_uid <> '0')
0.000275 - SELECT * FROM `users` WHERE uid IN (26882,2633,11509)
0.000109 - SELECT * FROM bb_online WHERE online_uid IN (26882,2633,11509)
0.000119 - SELECT groupid FROM groups_users_link WHERE uid=26882
0.000139 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 6 AND rank_max >= 6 AND rank_special = 0
0.000098 - SELECT groupid FROM groups_users_link WHERE uid=2633
0.000074 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000093 - SELECT * FROM smiles
0.000154 - SELECT groupid FROM groups_users_link WHERE uid=11509
0.000135 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 58 AND rank_max >= 58 AND rank_special = 0
0.000149 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000150 - SELECT post_id FROM bb_posts WHERE topic_id = 20406 AND pid = 0
0.000308 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Usage de la mémoire: 8316624 bytes
