116 Personne(s) en ligne (83 Personne(s) connectée(s) sur Forum)
Invité(s): 116
Voyants feu de croissement et phare en même temps
Post(s): 17
Je rencontre un problème et je sèche
Quand je suis en position "code" j'ai le voyant phare qui s'allume aussi.
J'ai démonter / nettoyer 100% le comodo et aucun résultat de positif..............Avez vous une idée?
Contribution le : 21/12/2017 19:43
Re: Voyants feu de croissement et phare en même temps
Post(s): 14
Change ton commodo
Contribution le : 24/01/2018 21:23
0.000216 - SET NAMES 'utf8'
0.000069 - SET SQL_BIG_SELECTS = 1
0.001427 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'ba27e2a06c1b0f626b69c738724c921f'
0.000457 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 378103
0.000057 - SELECT * FROM bb_forums WHERE forum_id = 33
0.000059 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000059 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('global_forum_access'))
0.000037 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '33' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000292 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20838
0.000272 - SELECT * FROM bb_topics WHERE topic_id=20838
0.000281 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20838 AND approved = 1
0.000635 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20838 AND approved = 1 AND post_id < 378103
0.000597 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20838 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.001689 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20838
0.000068 - SELECT * FROM bb_forums ORDER BY forum_order
0.000557 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001856 - UPDATE online SET online_updated=1793909974, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000351 - SELECT * FROM online
0.000289 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001362 - UPDATE online SET online_updated=1793909974, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000213 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.001458 - UPDATE bb_online SET online_updated= '1793909974', online_forum = '33', online_topic = '20838' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000314 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001416 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','86.41.130.37','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','46.128.8.6','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','178.43.244.182','109.242.90.144','157.22.72.59','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','122.8.47.151','85.208.96.195','178.115.91.172','195.81.191.106','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','106.73.159.193','90.233.195.169','85.208.96.207','27.79.121.243','87.241.157.54','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','173.33.114.42','190.145.240.183','185.191.171.13','199.201.92.59','51.175.158.185','85.208.96.209','216.73.216.244','66.9.171.28','85.208.96.193','91.82.240.128','85.208.96.196','90.14.5.65','93.117.164.200','201.4.71.213','152.232.247.173','213.232.122.23','85.208.96.206','190.99.23.153','102.38.1.172','155.133.78.47','66.249.70.192','138.84.47.240','134.249.12.43','79.106.215.227','103.181.127.136') )
0.000236 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20838'
0.000176 - SELECT * FROM bb_online WHERE (online_topic = '20838' AND online_uid <> '0')
0.000291 - SELECT * FROM `users` WHERE uid IN (26260,27324)
0.000188 - SELECT * FROM bb_online WHERE online_uid IN (26260,27324)
0.000049 - SELECT groupid FROM groups_users_link WHERE uid=26260
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 17 AND rank_max >= 17 AND rank_special = 0
0.000037 - SELECT groupid FROM groups_users_link WHERE uid=27324
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 14 AND rank_max >= 14 AND rank_special = 0
0.000059 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000209 - SELECT post_id FROM bb_posts WHERE topic_id = 20838 AND pid = 0
Total: 49
Usage de la mémoire: 8104832 bytes
XOOPS a mis 0.122 seconde(s) pour charger
Page rendering a mis 0.017 seconde(s) pour charger
