88 Personne(s) en ligne (56 Personne(s) connectée(s) sur Forum)
Invité(s): 88
Peinture sur jantes
Post(s): 28
Bonjour j aimerais bien peindre mes caches écrous en alu qui sont d origine sur les jantes de la f7r de 97 mais je ne sais pas si il faut un apres special et un peinture special pouvez vous m aider
Contribution le : 17/07/2018 14:00
0.000105 - SET NAMES 'utf8'
0.001066 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '3b1552444a3f9fe7068e3c99bec4f904'
0.000050 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000248 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 378995
0.000085 - SELECT * FROM bb_forums WHERE forum_id = 5
0.000067 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '5' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000203 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 21001
0.000104 - SELECT * FROM bb_topics WHERE topic_id=21001
0.000172 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=21001 AND approved = 1
0.000133 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=21001 AND approved = 1 AND post_id < 378995
0.000210 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=21001 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000601 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =21001
0.000071 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000292 - SELECT * FROM bb_forums ORDER BY forum_order
0.000263 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000522 - UPDATE online SET online_updated=1793905392, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000204 - SELECT * FROM online
0.000113 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000187 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000277 - UPDATE online SET online_updated=1793905392, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000132 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000468 - UPDATE bb_online SET online_updated= '1793905392', online_forum = '5', online_topic = '21001' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000157 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000637 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('193.56.20.216','185.191.171.8','82.174.26.146','87.58.192.51','85.106.157.136','190.5.37.222','66.249.70.193','185.191.171.15','85.208.96.209','85.208.96.204','102.211.11.219','202.141.53.37','144.76.23.213','31.105.111.224','66.249.70.192','66.249.84.39','168.222.30.35','130.49.9.119','146.19.78.235','82.24.234.194','202.46.62.2','185.191.171.11','202.46.62.1','88.203.120.76','64.49.39.109','37.114.150.33','82.22.239.31','177.131.77.132','5.183.252.197','103.115.158.82','179.0.127.5','130.49.115.202','104.165.6.83','1.55.95.221','84.50.221.175','85.147.110.244','40.77.167.7','185.191.171.1','187.0.233.82','66.249.64.7','31.105.113.78','92.130.80.145','186.19.123.106','5.91.183.159','85.208.96.211','109.177.246.61','140.235.0.242','216.73.216.84','85.208.96.212','192.101.65.230','177.92.50.67','202.46.62.14','46.185.191.197','170.84.9.84','84.203.198.50','83.175.180.223') )
0.000148 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '21001'
0.000212 - SELECT * FROM bb_online WHERE (online_topic = '21001' AND online_uid <> '0')
0.000200 - SELECT * FROM `users` WHERE uid IN (27447)
0.000112 - SELECT * FROM bb_online WHERE online_uid IN (27447)
0.000099 - SELECT groupid FROM groups_users_link WHERE uid=27447
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 28 AND rank_max >= 28 AND rank_special = 0
0.000090 - SELECT * FROM bb_categories WHERE cat_id = 3
0.000175 - SELECT post_id FROM bb_posts WHERE topic_id = 21001 AND pid = 0
Total: 47
Usage de la mémoire: 7988488 bytes
XOOPS a mis 0.094 seconde(s) pour charger
XOOPS output init a mis 0.027 seconde(s) pour charger
Module display a mis 0.016 seconde(s) pour charger
