Invité(s): 157
[coupé 2.0 f4r] Jose91
Post(s): 2
Bonjour nouveau sur ce forum je suis en possession de une megane coupe 1 phase 2 f4r746 je cherche à savoir comment préparer le moteur et si les pièces moteur de Clio 2 rs sont compatible merci de m accueillir sur ce forum
Contribution le : 13/08/2018 21:46
Edité par jef44 sur 15/08/2018 20:57:57
Re: [coupé 2.0 f4r] Jose91
bienvenue sur megane france, modèle rare chez nous! pas de prépa sur ce moteur à ma connaissance mais oui il y'a forcément du potentiel
Contribution le : 15/08/2018 20:59
0.000184 - SET NAMES 'utf8'
0.001044 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'f1da6077a0864241290883054531cb06'
0.001087 - SELECT COUNT(*) FROM group_permission WHERE (gperm_modid = '1' AND (gperm_groupid = '3') AND gperm_name = 'module_read' AND gperm_itemid = '5')
0.000118 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000477 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 379033
0.000093 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000078 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000074 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000315 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 21014
0.000900 - SELECT * FROM bb_topics WHERE topic_id=21014
0.040029 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=21014 AND approved = 1
0.000322 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=21014 AND approved = 1 AND post_id < 379033
0.000306 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=21014 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.002551 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =21014
0.000384 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000274 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000407 - UPDATE online SET online_updated=1793906222, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000232 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000586 - UPDATE online SET online_updated=1793906222, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000150 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.038718 - UPDATE bb_online SET online_updated= '1793906222', online_forum = '23', online_topic = '21014' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000317 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001299 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('185.191.171.13','109.174.150.40','31.216.91.238','45.132.187.214','52.167.144.141','90.46.141.250','84.122.229.149','189.162.184.152','185.191.171.16','46.185.191.197','5.31.195.185','87.56.23.217','166.114.128.28','154.246.32.94','62.204.49.250','185.191.171.6','185.77.223.189','86.45.209.138','162.141.97.158','185.195.185.78','188.187.15.75','87.197.92.130','87.56.23.39','109.174.146.87','102.0.31.4','105.113.102.255','85.208.96.197','105.108.219.242','115.76.126.43','155.4.125.107','185.191.171.2','102.253.64.25','37.131.43.187','85.208.96.202','46.254.47.67','102.212.197.190','105.107.216.215','46.34.249.163','185.191.171.17','80.32.2.178','103.59.38.33','185.135.69.82','102.88.169.178','66.249.70.194','66.249.70.202','94.16.41.116','197.234.87.219','202.46.62.61','190.174.110.142','191.23.75.89','186.251.6.179','5.134.86.124','66.249.70.201','188.241.101.242','85.208.96.206','94.205.209.188','185.217.190.156','57.134.176.141','190.57.181.1','181.131.74.254','38.211.32.164','187.112.13.131','196.238.219.122','195.81.136.135','66.249.70.192','201.4.87.28','169.224.12.76','45.189.63.27','102.66.145.29','116.204.166.57','91.132.124.222','31.36.227.51','105.110.204.203','46.149.92.13','195.81.154.173','66.249.70.195','216.73.216.84','46.162.203.26','92.41.50.111','177.115.3.168','24.16.219.183','187.190.11.189','66.249.70.197','197.188.227.96','66.249.70.193','66.249.64.6','181.87.167.147','77.207.54.11','185.191.171.10','45.234.16.166','157.22.44.123','37.67.46.5','185.81.144.203','185.191.171.4','105.74.0.46','45.67.171.92','83.134.25.230','66.249.70.196','185.201.139.202','68.167.156.165','85.208.96.203','191.242.55.33','185.190.132.139','202.46.61.76','181.115.174.28','209.212.220.178','41.193.163.152','85.208.96.207','185.191.171.3','77.46.175.227','62.65.228.98','192.101.65.200','78.181.17.152','181.79.88.199','103.203.37.35','66.249.70.199','85.208.96.209','196.189.57.103','66.249.64.8','66.249.64.7','190.110.179.61','212.119.47.150','45.147.8.182') )
0.000179 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '21014'
0.000131 - SELECT * FROM bb_online WHERE (online_topic = '21014' AND online_uid <> '0')
0.000293 - SELECT * FROM `users` WHERE uid IN (27534,1315)
0.000125 - SELECT * FROM bb_online WHERE online_uid IN (27534,1315)
0.000177 - SELECT groupid FROM groups_users_link WHERE uid=27534
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 2 AND rank_max >= 2 AND rank_special = 0
0.000080 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000177 - SELECT post_id FROM bb_posts WHERE topic_id = 21014 AND pid = 0
Total: 49
Usage de la mémoire: 8118848 bytes
XOOPS a mis 0.229 seconde(s) pour charger
Module init a mis 0.062 seconde(s) pour charger
