136 Personne(s) en ligne (96 Personne(s) connectée(s) sur Forum)
Invité(s): 136
« 1 2 3 (4)
Re: [Coupé 2.0 Lazuli] teambooster18
Optimista a écrit:
I know about tutorial, but when i translate on english I don't understand a few things :/
pas facile de t'expliquer comme ça, en gros y'a un fils du commodo a tirer au compteur, le commodo doit déja etre a la masse de mémoire, puis un de la boite a fusible coter moteur au compteur et ca fonctionne
Contribution le : 16/09/2018 17:24
« 1 2 3 (4)
0.000168 - SET NAMES 'utf8'
0.001234 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'ba27e2a06c1b0f626b69c738724c921f'
0.000316 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 379099
0.000046 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000298 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20841
0.000148 - SELECT * FROM bb_topics WHERE topic_id=20841
0.000037 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20841 AND approved = 1
0.000648 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20841 AND approved = 1 AND post_id < 379099
0.001591 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20841 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 90, 30
0.001917 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20841
0.000070 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000211 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000069 - SELECT * FROM groups
0.000055 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000469 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000187 - UPDATE online SET online_updated=1793910010, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000333 - SELECT * FROM online
0.000243 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.001755 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000640 - UPDATE online SET online_updated=1793910010, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000565 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.244'
0.000969 - UPDATE bb_online SET online_updated= '1793910010', online_forum = '23', online_topic = '20841' WHERE online_uid = 0 AND online_ip='216.73.216.244'
0.000566 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001353 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('202.46.62.35','5.241.139.159','31.134.3.105','213.6.102.191','86.41.130.37','91.127.8.193','86.176.131.23','186.77.206.155','122.8.45.30','41.214.3.214','195.36.204.216','41.60.90.222','116.96.78.115','41.208.141.74','93.152.80.68','216.147.125.54','165.162.147.132','95.84.66.119','45.80.107.214','185.101.21.206','185.191.171.5','66.249.84.33','46.128.8.6','178.40.240.129','38.51.121.60','79.177.131.91','185.191.171.1','200.149.89.194','31.105.105.36','41.74.138.65','23.230.40.155','85.208.96.212','178.43.244.182','109.242.90.144','157.22.72.59','185.191.171.16','93.152.85.28','176.124.236.241','90.36.61.149','202.46.61.135','202.46.62.32','157.55.39.204','45.65.167.138','109.245.151.204','38.74.245.120','109.196.67.205','45.66.210.122','92.208.38.143','198.91.152.111','221.153.124.214','155.4.206.246','186.91.18.171','106.73.159.193','90.233.195.169','41.83.45.142','27.79.121.243','212.93.153.39','188.151.133.137','185.191.171.11','109.81.12.155','202.46.61.89','197.146.138.106','87.125.178.27','88.0.91.243','173.33.114.42','190.145.240.183','14.231.252.236','185.191.171.13','199.201.92.59','85.208.96.209','216.73.216.244','66.9.171.28','200.180.238.253','177.70.165.214','85.208.96.193','91.82.240.128','85.217.249.150','152.249.11.244','90.14.5.65','93.117.164.200','201.4.71.213','213.232.122.23','85.208.96.206','185.244.154.87','190.99.23.153','102.38.1.172','155.133.78.47','40.77.167.235','66.249.70.192','138.84.47.240','134.249.12.43','201.180.185.250','191.108.51.228','79.106.215.227','40.77.167.121','103.181.127.136') )
0.000243 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20841'
0.000176 - SELECT * FROM bb_online WHERE (online_topic = '20841' AND online_uid <> '0')
0.000278 - SELECT * FROM `users` WHERE uid IN (3711)
0.000132 - SELECT * FROM bb_online WHERE online_uid IN (3711)
0.000036 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000166 - SELECT * FROM smiles
0.000085 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000035 - SELECT post_id FROM bb_posts WHERE topic_id = 20841 AND pid = 0
Total: 47
Usage de la mémoire: 8063840 bytes
XOOPS a mis 0.306 seconde(s) pour charger
Page rendering a mis 0.103 seconde(s) pour charger
