180 Personne(s) en ligne (158 Personne(s) connectée(s) sur Forum)
Invité(s): 180
Post(s): 316
Non, celle ci
isotak a écrit:
Post(s): 590
Le poid,c est l ennemie...
Réponse en image !
Post(s): 316
il a l'air plus lisse non ?
ShInGiN a écrit:
Oui faut etre bien motivé...
Donc voila en photo
Et une fois intégré !
C'est bien intégrer comme ca.
De Nord
Post(s): 650
A bientôt.
FAB.
FAB alias Aspec
Clio...., Megane 3 RS
TOP
Merci les gars!
Post(s): 590
0.000104 - SET NAMES 'utf8'
0.000828 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0376531ed599091e42ef7e847cd0d311'
0.000215 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000226 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 5629
0.000024 - SELECT * FROM bb_topics WHERE topic_id=5629
0.000028 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=5629 AND approved = 1
0.014225 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=5629 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 1890, 30
0.004214 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =5629
0.000065 - SELECT b.* FROM newblocks b, block_module_link m WHERE m.block_id=b.bid AND b.isactive=1 AND b.visible=1 AND m.module_id IN (0,5) AND b.bid IN (134,133,131,119,118,117,116,115,114,101,100,99,98,26,14,13,12,11,10,8,7,6,5,3,2,1,135,129,128,127,126,125,124,123,122,121,41,40,39,34,136,35,32,139,140,141,142,143,144,145,147,148,149,150,151,152,153,154,155,156,157) ORDER BY b.weight, m.block_id
0.000103 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000383 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000679 - UPDATE online SET online_updated=1792766546, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000287 - SELECT * FROM online
0.000140 - SELECT COUNT(*) FROM online WHERE online_module = '5'
0.000277 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000578 - UPDATE online SET online_updated=1792766546, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000174 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.110'
0.000787 - UPDATE bb_online SET online_updated= '1792766546', online_forum = '23', online_topic = '5629' WHERE online_uid = 0 AND online_ip='216.73.217.110'
0.000259 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001394 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('172.121.11.135','172.120.249.125','191.181.57.26','108.206.63.169','93.87.121.180','176.144.240.113','177.118.165.45','14.192.135.21','185.191.171.5','207.32.156.108','195.40.125.241','179.127.249.83','87.239.86.218','201.25.175.238','76.34.112.173','192.177.122.238','102.69.36.150','69.17.18.115','201.24.163.174','94.131.79.40','93.152.53.0','74.7.241.29','87.232.201.133','186.52.208.241','85.208.96.203','85.208.96.197','220.181.108.174','216.73.217.110','82.158.130.33','85.208.96.212','178.233.188.167','104.165.187.41','38.25.25.229','45.124.171.204','69.17.18.26','161.142.145.54','23.108.72.113','185.191.171.11','207.32.153.23','41.188.109.120','196.171.30.19','45.93.96.154','213.188.176.114','172.121.11.224','190.143.240.180','177.192.19.126','94.233.97.162','88.97.221.44','87.232.152.67','154.116.98.157','88.99.95.199','151.123.148.1','46.152.17.11','81.166.61.250','123.50.47.115','64.52.24.13','103.237.39.56','94.228.30.156','104.252.38.167','85.208.96.208','185.191.171.15','185.191.171.14','86.108.33.174','190.43.252.17','208.190.195.247','172.121.255.187','193.179.119.35','170.233.4.83','207.32.135.208','61.6.241.180','189.104.241.3','150.241.241.104','220.181.108.94','104.164.250.199','115.186.119.95','84.50.48.237','85.208.96.206','188.239.241.111','197.206.69.98','104.252.94.39','104.252.7.145','82.199.223.122','185.191.171.4','89.114.179.125','179.209.31.184','92.96.160.59','172.120.139.36','38.25.229.151','91.151.136.175','189.104.204.83','45.229.156.22','192.177.166.65','172.252.120.151','207.32.139.180','143.255.134.50','201.32.189.46','83.167.40.95','189.104.240.29','85.208.96.205','71.193.106.238','125.162.247.87','185.200.61.226','85.208.96.201','179.60.95.83','181.188.178.68','37.159.81.124','170.254.213.16','189.63.12.218','90.21.47.150','103.133.121.237','172.121.96.152','72.63.71.28','216.98.214.120','160.178.163.121','85.208.96.196','72.63.249.234','176.20.211.123','197.113.107.116','192.177.105.249','64.52.26.239','190.89.81.225','85.208.96.193','103.153.199.217','85.208.96.210','76.184.42.127','170.80.40.78','177.124.106.2','105.172.141.15','14.247.193.59','211.184.153.64','189.81.70.10','185.191.171.16','186.22.54.165','104.165.210.208','185.191.171.18','212.241.16.111','175.100.46.189','85.208.96.202','85.208.96.207','104.253.135.247','104.253.160.52','79.12.55.202','162.141.20.147','172.121.96.41','85.208.98.56','172.121.37.50','207.32.129.233','207.191.175.49','192.177.93.58','85.208.96.211','185.191.171.13','141.8.202.241','94.239.133.101','86.45.207.43','189.81.71.106','177.227.109.117','87.232.147.118','178.135.18.84') )
0.000184 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '5629'
0.000182 - SELECT * FROM bb_online WHERE (online_topic = '5629' AND online_uid <> '0')
0.000511 - SELECT * FROM `users` WHERE uid IN (6934,1611,1315,4383,841,133,5,21,1804,4050,9887)
0.000856 - SELECT * FROM bb_online WHERE online_uid IN (6934,1611,1315,4383,841,133,5,21,1804,4050,9887)
0.000280 - SELECT groupid FROM groups_users_link WHERE uid=6934
0.000179 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 316 AND rank_max >= 316 AND rank_special = 0
0.000035 - SELECT groupid FROM groups_users_link WHERE uid=1611
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=133
0.000026 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 590 AND rank_max >= 590 AND rank_special = 0
0.000130 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000117 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 6
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=1804
0.000028 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 650 AND rank_max >= 650 AND rank_special = 0
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=9887
0.000113 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 5629 AND pid = 0
0.000152 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '2') ORDER BY conf_order ASC
Total: 66
Usage de la mémoire: 10223920 bytes
Module init a mis 0.031 seconde(s) pour charger
