295 Personne(s) en ligne (242 Personne(s) connectée(s) sur Forum)
Invité(s): 295
« 1 (2)
Re: vidange boite==> nfj ou nfp?
Post(s): 5
c'est pas simple...
dans le manuel d'origine,il est indiqué TRX, désormais remplacé par la NFP, jusque la tout va bien.
sauf que:
http://www.lubadmin.com/upload/produit/FichePDF/lang_1/7195.pdf
http://www.lubadmin.com/upload/produit/fichepdf/lang_5/1075.pdf
pffffffffff
Contribution le : 17/09/2016 07:13
« 1 (2)
0.000103 - SET NAMES 'utf8'
0.001117 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'be0609253abcbc88dbc3e5024683c8f7'
0.000218 - SELECT * FROM bb_topics WHERE topic_id=10861
0.000110 - SELECT * FROM bb_forums WHERE forum_id = 9
0.000091 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '9' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000270 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 10861
0.000224 - SELECT * FROM bb_topics WHERE topic_id=10861
0.000073 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=10861 AND approved = 1
0.000560 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=10861 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 30, 30
0.000433 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =10861
0.000091 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000122 - SELECT * FROM modules WHERE dirname = 'mylinks'
0.000176 - DELETE FROM online WHERE online_updated < 1792634271
0.000236 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000436 - UPDATE online SET online_updated=1792634571, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000324 - SELECT * FROM online
0.000213 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000390 - UPDATE online SET online_updated=1792634571, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.002475 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.171'
0.000745 - UPDATE bb_online SET online_updated= '1792634571', online_forum = '9', online_topic = '10861' WHERE online_uid = 0 AND online_ip='216.73.216.171'
0.000521 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.002398 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('93.45.61.41','188.78.53.98','190.84.119.150','179.97.29.31','72.63.159.246','177.84.175.137','181.133.39.163','185.191.171.19','79.176.48.207','201.13.206.240','179.62.70.22','45.228.139.76','45.112.46.195','72.27.119.174','89.152.67.68','90.11.69.112','103.69.151.216','74.7.241.29','102.102.106.252','93.35.216.176','103.86.57.99','41.236.74.6','220.181.108.80','88.147.152.191','88.189.105.18','88.19.53.138','88.170.106.223','212.105.138.211','43.172.197.24','43.173.182.231','45.131.172.159','41.208.137.183','81.57.112.42','143.0.56.60','189.161.95.84','113.160.205.246','108.192.65.22','186.123.216.172','172.121.96.151','192.24.57.42','85.208.96.197','212.180.24.24','94.202.13.130','176.205.175.91','85.208.96.203','41.249.44.132','179.125.139.221','86.22.99.121','92.209.240.250','178.88.95.13','102.189.145.71','189.175.224.12','197.184.98.218','116.108.140.34','186.10.104.139','45.187.0.58','43.173.176.62','193.148.48.23','185.191.171.5','62.192.107.217','125.235.233.112','45.168.185.180','79.49.57.228','189.203.145.144','154.179.209.177','167.250.142.171','187.153.175.119','172.56.119.179','191.181.255.110','38.25.80.241','23.27.31.135','186.12.190.1','43.172.195.212','43.173.178.169','93.4.40.51','43.173.180.207','104.243.208.13','177.36.176.190','24.0.90.189','212.108.113.227','160.32.75.58','62.45.37.186','78.150.199.220','149.86.162.138','92.28.203.111','86.135.11.70','166.199.100.37','91.89.142.94','102.104.129.72','191.241.188.245','200.220.167.187','68.131.88.114','129.222.193.151','40.77.167.32','195.40.125.69','48.47.30.160','185.191.171.3','43.172.195.104','168.121.200.75','170.246.47.66','172.58.182.229','100.15.21.186','48.47.11.7','86.248.163.89','189.113.185.102','201.226.207.66','181.209.102.242','189.238.134.134','189.110.116.121','37.142.149.81','181.13.252.72','48.47.11.29','194.58.180.102','173.8.230.36','38.10.254.61','103.124.250.48','102.103.234.78','93.233.226.227','177.236.34.23','138.36.56.227','170.100.129.140','137.103.238.187','108.234.72.70','191.97.54.13','103.199.155.230','185.191.171.9','93.156.217.107','188.248.183.8','200.189.27.55','49.145.160.7','197.147.17.122','205.188.172.143','186.226.218.45','190.151.16.36','88.97.209.156','31.98.2.196','85.208.96.200','40.77.167.78','189.39.181.81','201.146.175.67','102.217.241.232','156.197.246.115','137.97.184.98','122.167.96.248','196.188.37.197','79.117.212.73','45.162.39.250','189.148.164.11','45.238.183.34','72.63.127.48','177.227.77.234','45.224.115.26','185.191.171.13','103.72.87.70','209.166.24.87','70.228.120.97','187.4.20.96','180.74.170.157','23.230.111.18','166.0.18.113','85.208.96.210','198.145.140.60','89.42.124.32','143.208.148.71','38.248.159.122','209.166.28.142','78.158.217.114','179.162.110.106','196.87.11.53','153.79.115.175','43.173.180.32','43.173.179.79','45.160.118.94','72.63.189.25','72.63.190.85','87.123.194.89','73.213.0.139','113.199.228.137','177.125.120.108','45.117.242.228','168.195.2.158','179.60.70.143','181.71.118.209','187.190.184.222','86.154.254.15','172.56.148.67','189.239.216.17','40.77.167.45','116.204.143.87','185.92.139.223','85.208.96.204','197.53.97.204','182.48.231.37','77.136.66.226','187.45.57.109','82.108.107.217','43.173.181.158','170.100.128.29','72.63.157.234','168.167.18.188','72.63.157.112','104.221.74.63','179.63.93.28','95.72.152.165','144.124.192.90','151.82.168.106','185.235.103.148','72.63.125.63','116.204.108.79','64.56.4.150','191.99.21.183','201.14.252.142','186.178.65.201','181.87.24.177','213.169.249.58','177.68.24.251','85.251.126.50','179.64.43.62','190.2.71.221','140.206.235.3','85.208.96.212','201.59.90.123','205.188.190.98','188.119.54.245','153.79.114.241','91.254.218.62','45.170.238.50','75.15.225.58','151.158.121.67','216.73.216.171','131.72.87.206','188.216.32.245','181.40.12.44','58.136.174.160','177.55.180.239','177.10.87.179','72.63.191.200','200.52.30.53','86.38.118.226','186.22.225.158','176.228.54.138','182.11.153.93','186.50.255.161') )
0.000196 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '10861'
0.000129 - SELECT * FROM bb_online WHERE (online_topic = '10861' AND online_uid <> '0')
0.000235 - SELECT * FROM `users` WHERE uid IN (26805)
0.000120 - SELECT * FROM bb_online WHERE online_uid IN (26805)
0.000201 - SELECT groupid FROM groups_users_link WHERE uid=26805
0.000097 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 5 AND rank_max >= 5 AND rank_special = 0
0.000098 - SELECT * FROM bb_categories WHERE cat_id = 1
0.000025 - SELECT post_id FROM bb_posts WHERE topic_id = 10861 AND pid = 0
Total: 47
Usage de la mémoire: 8027688 bytes
XOOPS a mis 0.133 seconde(s) pour charger
