117 Personne(s) en ligne (86 Personne(s) connectée(s) sur Forum)
Invité(s): 117
Voyants feu de croissement et phare en même temps
Post(s): 17
Je rencontre un problème et je sèche
Quand je suis en position "code" j'ai le voyant phare qui s'allume aussi.
J'ai démonter / nettoyer 100% le comodo et aucun résultat de positif..............Avez vous une idée?
Contribution le : 21/12/2017 19:43
Re: Voyants feu de croissement et phare en même temps
Post(s): 14
Change ton commodo
Contribution le : 24/01/2018 21:23
0.000157 - SET NAMES 'utf8'
0.001013 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '49d90b6357197e0d1840ba6294a57361'
0.000271 - SELECT * FROM bb_topics WHERE topic_id=20838
0.000075 - SELECT * FROM bb_forums WHERE forum_id = 33
0.000061 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_name IN ('forum_cat_access'))
0.000057 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '33' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000226 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 20838
0.000030 - SELECT * FROM bb_topics WHERE topic_id=20838
0.000208 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=20838 AND approved = 1
0.000231 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=20838 AND p.post_id = t.post_id AND p.approved = 1 ORDER BY p.post_id ASC LIMIT 0, 30
0.000830 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =20838
0.000078 - SELECT DISTINCT gperm_itemid FROM group_permission WHERE gperm_name = 'block_read' AND gperm_modid = 1 AND gperm_groupid IN (3)
0.000315 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.000518 - UPDATE online SET online_updated=1793906156, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000332 - SELECT * FROM online
0.036585 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.001252 - UPDATE online SET online_updated=1793906156, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.050407 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.216.84'
0.073543 - UPDATE bb_online SET online_updated= '1793906156', online_forum = '33', online_topic = '20838' WHERE online_uid = 0 AND online_ip='216.73.216.84'
0.000673 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001010 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('62.204.49.250','185.191.171.6','185.77.223.189','86.45.209.138','162.141.97.158','185.195.185.78','188.187.15.75','87.197.92.130','87.56.23.39','109.174.146.87','102.0.31.4','105.113.102.255','85.208.96.197','105.108.219.242','115.76.126.43','155.4.125.107','185.191.171.2','102.253.64.25','37.131.43.187','85.208.96.202','185.191.171.17','80.32.2.178','103.59.38.33','185.135.69.82','66.249.70.202','38.183.115.146','94.16.41.116','197.234.87.219','202.46.62.61','190.174.110.142','191.23.75.89','186.251.6.179','5.134.86.124','66.249.70.201','168.222.82.41','85.208.96.206','196.238.219.122','195.81.136.135','66.249.70.192','91.132.124.222','31.36.227.51','122.8.46.18','85.208.96.195','195.81.154.173','66.249.70.195','216.73.216.84','46.162.203.26','92.41.50.111','177.115.3.168','24.16.219.183','187.190.11.189','66.249.70.197','66.249.70.193','66.249.64.6','77.207.54.11','185.191.171.10','45.234.16.166','157.22.44.123','37.67.46.5','93.148.111.30','149.200.77.35','45.67.171.92','83.134.25.230','66.249.70.196','185.201.139.202','68.167.156.165','85.208.96.203','177.131.77.132','185.190.132.139','202.46.61.76','209.212.220.178','195.81.148.7','85.208.96.207','185.191.171.3','62.65.228.98','192.101.65.200','78.181.17.152','103.203.37.35','66.249.70.199','85.208.96.209','196.189.57.103','66.249.64.8','66.249.64.7','190.110.179.61','212.119.47.150','45.147.8.182') )
0.000348 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '20838'
0.000173 - SELECT * FROM bb_online WHERE (online_topic = '20838' AND online_uid <> '0')
0.008511 - SELECT * FROM `users` WHERE uid IN (26260,27324)
0.000676 - SELECT * FROM bb_online WHERE online_uid IN (26260,27324)
0.000099 - SELECT groupid FROM groups_users_link WHERE uid=26260
0.000030 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 17 AND rank_max >= 17 AND rank_special = 0
0.000062 - SELECT groupid FROM groups_users_link WHERE uid=27324
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 14 AND rank_max >= 14 AND rank_special = 0
0.000074 - SELECT * FROM smiles
0.000180 - SELECT post_id FROM bb_posts WHERE topic_id = 20838 AND pid = 0
Total: 48
Usage de la mémoire: 8117272 bytes
XOOPS a mis 0.326 seconde(s) pour charger
Module display a mis 0.199 seconde(s) pour charger
