240 Personne(s) en ligne (189 Personne(s) connectée(s) sur Forum)
Invité(s): 240
De Bouaye (44)
Post(s): 356
Post(s): 276
Post(s): 1410
sympa ces disques
ca va freiner
autant pour moi
non rien senti au retour.
sa te fait quoi comme bruit?
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
0.000102 - SET NAMES 'utf8'
0.000745 - SELECT sess_data, sess_ip FROM session WHERE sess_id = 'bd5151cc474b3d2574c4383460c9d288'
0.000047 - SELECT * FROM modules WHERE dirname = 'newbb'
0.000498 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 180976
0.000087 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000229 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3933
0.000099 - SELECT * FROM bb_topics WHERE topic_id=3933
0.000030 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3933 AND approved = 1
0.000995 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3933 AND approved = 1 AND post_id < 180976
0.003647 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3933 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 240, 30
0.000354 - SELECT * FROM bb_forums ORDER BY forum_order
0.000190 - SELECT * FROM config WHERE (conf_modid = '3') ORDER BY conf_order ASC
0.000273 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.001420 - UPDATE online SET online_updated=1789941008, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000300 - SELECT * FROM online
0.002109 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000498 - UPDATE online SET online_updated=1789941008, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000213 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.001171 - UPDATE bb_online SET online_updated= '1789941008', online_forum = '23', online_topic = '3933' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000391 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.002778 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('85.58.30.186','66.249.68.193','178.225.166.2','85.208.96.193','34.134.185.175','35.224.103.75','35.193.15.59','34.28.30.77','34.135.98.122','104.198.177.225','35.254.201.217','34.132.249.233','34.134.246.204','34.29.77.190','85.208.96.202','104.165.247.19','187.56.83.38','34.58.244.105','35.222.247.211','34.45.53.200','34.173.64.78','34.30.230.50','35.202.50.196','85.208.96.203','189.203.193.226','136.119.87.190','34.66.90.28','216.73.217.83','35.254.208.237','35.254.25.136','68.166.166.56','85.208.96.198','34.71.243.182','34.44.229.100','34.10.138.17','34.44.200.48','34.172.78.224','35.202.11.48','34.29.246.143','34.29.186.28','136.112.32.154','35.226.87.141','136.65.150.131','34.68.177.213','136.112.237.154','136.113.250.234','34.9.203.105','34.41.163.232','34.172.85.78','34.136.179.114','136.65.65.243','34.31.95.75','136.115.0.150','34.56.146.15','34.44.114.244','34.27.43.36','34.136.104.39','136.112.177.219','34.63.130.210','35.255.220.188','34.30.142.93','35.255.64.216','136.114.7.39','136.119.240.126','35.184.81.141','34.170.20.48','34.42.190.171','34.28.137.40','85.208.98.58','35.253.61.23','169.224.2.4','85.208.96.194','66.249.68.192','34.30.233.192','34.170.117.47','35.232.21.128','136.114.178.72','136.64.154.238','34.134.224.139','34.55.37.33','35.255.139.26','34.27.99.191','136.112.169.254','73.198.88.153','34.133.64.91','34.66.2.52','35.222.231.60','116.206.97.210','35.226.113.131','35.226.190.245','34.171.232.236','79.145.134.67','34.41.65.37','52.167.144.147','111.225.214.167','185.191.171.18','136.65.144.175','104.198.47.65','85.208.98.55','34.10.84.36','34.135.47.220','156.146.143.211','85.208.98.57','34.123.129.208','35.223.180.90','189.58.74.246','200.46.55.59','176.98.23.241','35.225.92.119','136.65.73.35','34.9.131.229','71.178.214.58','34.31.12.118','34.30.52.134','136.114.251.171','103.65.118.76','34.31.207.226','35.238.73.253','136.115.16.60','34.57.28.101','103.145.75.63','90.25.134.77','136.114.251.213','34.71.18.247','35.239.86.222','34.60.251.45','69.94.12.178','34.66.127.248','52.167.144.166','34.28.60.93','34.173.48.161','181.177.113.53','34.42.103.145','35.226.130.30','34.55.56.100','35.255.232.183','35.193.255.230','34.171.114.96','136.65.206.196','35.192.61.174','85.208.96.206','34.72.19.252','34.136.50.121','34.29.229.26','34.59.220.183','136.115.172.248','136.116.59.242','35.226.94.124','136.113.248.41','34.172.220.235','35.225.72.94','34.133.150.125','35.192.131.166','34.57.115.209','34.9.180.63','34.56.106.168','35.226.106.205','132.255.185.3','136.64.93.95','34.59.183.133','83.167.40.95','34.55.227.40','35.202.223.123','34.59.68.27','35.253.40.20','34.135.218.57','85.208.98.59','34.31.187.131','136.115.148.7','34.66.45.93','34.71.205.180','34.44.37.232','34.67.133.93','35.222.110.111','34.16.86.184','194.246.91.155','34.135.220.83','35.239.226.56','34.10.108.251','104.198.16.217','146.148.110.159','136.65.57.107','35.225.182.77','35.193.156.72','34.67.245.67','34.46.146.70','35.184.229.62','150.107.106.8','34.63.146.186') )
0.000268 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3933'
0.000279 - SELECT * FROM bb_online WHERE (online_topic = '3933' AND online_uid <> '0')
0.000627 - SELECT * FROM `users` WHERE uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000375 - SELECT * FROM bb_online WHERE online_uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=1315
0.000045 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 8350 AND rank_max >= 8350 AND rank_special = 0
0.000044 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 7
0.000048 - SELECT groupid FROM groups_users_link WHERE uid=2982
0.000038 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000037 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=419
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=2529
0.000035 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 276 AND rank_max >= 276 AND rank_special = 0
0.000043 - SELECT groupid FROM groups_users_link WHERE uid=3050
0.000037 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1410 AND rank_max >= 1410 AND rank_special = 0
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=2152
0.000039 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000211 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000220 - SELECT post_id FROM bb_posts WHERE topic_id = 3933 AND pid = 0
Total: 66
Usage de la mémoire: 10225384 bytes
XOOPS a mis 0.761 seconde(s) pour charger
Module init a mis 0.061 seconde(s) pour charger
XOOPS output init a mis 0.294 seconde(s) pour charger
Module display a mis 0.151 seconde(s) pour charger
Page rendering a mis 0.239 seconde(s) pour charger
