235 Personne(s) en ligne (185 Personne(s) connectée(s) sur Forum)
Invité(s): 235
De Bouaye (44)
Post(s): 356
Post(s): 276
Post(s): 1410
sympa ces disques
ca va freiner
autant pour moi
non rien senti au retour.
sa te fait quoi comme bruit?
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
De Poitiers - 86
Post(s): 2118
0.000104 - SET NAMES 'utf8'
0.000158 - SELECT * FROM config WHERE (conf_modid = '0' AND conf_catid = '1') ORDER BY conf_order ASC
0.001125 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '3c13802b931644d1e06cfe72250f5d63'
0.000124 - SELECT * FROM config WHERE (conf_modid = '5') ORDER BY conf_order ASC
0.000300 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 180991
0.000145 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000118 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000220 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 3933
0.000142 - SELECT * FROM bb_topics WHERE topic_id=3933
0.000035 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3933 AND approved = 1
0.001027 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=3933 AND approved = 1 AND post_id < 180991
0.000310 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=3933 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 240, 30
0.000457 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =3933
0.000203 - SELECT * FROM groups
0.000556 - DELETE FROM online WHERE online_updated < 1789940823
0.000169 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000540 - UPDATE online SET online_updated=1789941123, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000296 - SELECT * FROM online
0.000413 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.000712 - UPDATE online SET online_updated=1789941123, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000158 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.83'
0.001326 - UPDATE bb_online SET online_updated= '1789941123', online_forum = '23', online_topic = '3933' WHERE online_uid = 0 AND online_ip='216.73.217.83'
0.000492 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.001727 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.68.193','178.225.166.2','85.208.96.193','34.134.185.175','35.224.103.75','35.193.15.59','34.28.30.77','34.135.98.122','35.254.195.237','35.254.201.217','34.132.249.233','136.111.70.61','34.29.77.190','34.42.103.145','34.46.92.63','34.58.244.105','35.222.247.211','34.45.53.200','34.173.64.78','88.175.152.86','35.202.50.196','189.203.193.226','136.119.87.190','34.66.90.28','216.73.217.83','35.254.208.237','136.64.154.238','68.166.166.56','34.172.174.93','85.208.96.198','34.41.18.53','34.44.229.100','34.44.200.48','35.202.107.105','34.172.78.224','35.202.11.48','34.29.246.143','34.29.186.28','136.112.32.154','34.170.20.48','34.61.148.235','66.249.68.194','213.204.127.6','136.112.237.154','136.113.250.234','34.27.99.191','34.41.163.232','34.172.85.78','34.136.179.114','34.31.95.75','136.115.0.150','34.56.146.15','34.44.114.244','220.181.108.103','104.154.189.181','34.136.104.39','136.112.177.219','34.63.130.210','35.255.220.188','34.30.142.93','35.255.64.216','35.184.81.141','85.208.96.203','34.42.190.171','34.28.137.40','85.208.98.58','104.197.166.106','169.224.2.4','85.208.96.194','66.249.68.192','34.30.233.192','174.23.241.111','34.134.224.139','34.55.37.33','35.255.139.26','35.226.83.174','136.112.169.254','73.198.88.153','34.66.2.52','35.222.231.60','116.206.97.210','35.226.190.245','34.171.232.236','79.145.134.67','34.41.65.37','85.49.137.254','35.194.37.141','52.167.144.147','111.225.214.167','185.191.171.18','136.65.144.175','104.198.47.65','85.208.98.55','34.10.84.36','34.135.47.220','156.146.143.211','85.208.98.57','35.254.235.190','34.173.138.43','35.223.180.90','189.58.74.246','200.46.55.59','176.98.23.241','35.225.92.119','136.65.73.35','34.9.131.229','34.60.121.79','34.28.219.45','85.208.96.204','71.178.214.58','34.31.12.118','34.30.52.134','136.114.251.171','34.31.207.226','85.208.96.209','34.57.28.101','103.145.75.63','90.25.134.77','136.111.73.51','136.114.251.213','34.71.18.247','35.239.86.222','69.94.12.178','38.252.202.9','52.167.144.166','34.28.60.93','34.173.48.161','181.177.113.53','34.55.56.100','35.255.232.183','35.193.255.230','34.171.114.96','35.192.61.174','34.44.249.127','35.184.42.130','136.115.95.158','34.72.19.252','34.59.220.183','136.115.172.248','136.116.59.242','35.226.94.124','136.113.248.41','34.29.26.240','35.225.72.94','34.133.150.125','35.192.131.166','34.9.180.63','34.69.172.88','35.226.106.205','132.255.185.3','136.64.93.95','64.29.19.219','83.167.40.95','34.55.227.40','35.202.223.123','34.59.68.27','35.253.40.20','34.135.218.57','34.67.161.204','136.114.190.91','85.208.98.59','46.60.7.63','34.31.187.131','136.115.148.7','34.66.45.93','34.71.205.180','34.10.108.251','34.44.37.232','85.208.96.197','35.222.110.111','34.16.86.184','194.246.91.155','34.135.220.83','35.239.226.56','34.67.133.93','104.198.16.217','136.65.57.107','204.141.207.24','34.136.111.60','35.193.156.72','34.46.146.70','35.184.229.62','150.107.106.8','34.63.146.186','85.208.96.210') )
0.000185 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '3933'
0.000269 - SELECT * FROM bb_online WHERE (online_topic = '3933' AND online_uid <> '0')
0.000071 - SELECT * FROM `users` WHERE uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000629 - SELECT * FROM bb_online WHERE online_uid IN (1315,1,2982,5,419,2529,3050,21,2152,841,1779)
0.000066 - SELECT groupid FROM groups_users_link WHERE uid=1
0.000071 - SELECT groupid FROM groups_users_link WHERE uid=2982
0.000028 - SELECT groupid FROM groups_users_link WHERE uid=5
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=419
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=2529
0.000027 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 276 AND rank_max >= 276 AND rank_special = 0
0.000068 - SELECT groupid FROM groups_users_link WHERE uid=3050
0.000022 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1410 AND rank_max >= 1410 AND rank_special = 0
0.000123 - SELECT groupid FROM groups_users_link WHERE uid=2152
0.000290 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000040 - SELECT groupid FROM groups_users_link WHERE uid=841
0.000119 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000026 - SELECT post_id FROM bb_posts WHERE topic_id = 3933 AND pid = 0
Usage de la mémoire: 10225648 bytes
XOOPS a mis 0.283 seconde(s) pour charger
Page rendering a mis 0.125 seconde(s) pour charger
