78 Personne(s) en ligne (76 Personne(s) connectée(s) sur Forum)
Invité(s): 78
Fait toi aider.Et fait l'eux.
Kew-Kedew a écrit:
De Saumur 49 Maine et Loire
Post(s): 470
Mégane Coupé Ph2 1.6 16V RSI
du pédalier
sinon voila quelle que photos
De Nantes (44)
Post(s): 1123
Arff la jante a bien plié :-o
un becquet?
mikl68 a écrit:
un becquet?
sa je les dejas
Post(s): 1386
Post(s): 1175
Ah oui #censuré#!
Post(s): 1175
Post(s): 1175
j'espere bien pas cartonné
0.000109 - SET NAMES 'utf8'
0.000968 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '7afb7a16d595a5e4dfa98ea084477031'
0.000549 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 239661
0.000077 - SELECT * FROM bb_forums WHERE forum_id = 23
0.000062 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000209 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 11524
0.000118 - SELECT * FROM bb_topics WHERE topic_id=11524
0.000067 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=11524 AND approved = 1
0.001245 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=11524 AND approved = 1 AND post_id < 239661
0.000054 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=11524 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 330, 30
0.000497 - UPDATE bb_topics SET topic_views = topic_views + 1 WHERE topic_id =11524
0.000490 - SELECT * FROM modules WHERE (hasmain = '1' AND isactive = '1' AND weight > '0') ORDER BY weight ASC, mid ASC
0.000243 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000554 - UPDATE online SET online_updated=1777606581, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000173 - SELECT * FROM online
0.000176 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000586 - UPDATE online SET online_updated=1777606581, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000138 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000947 - UPDATE bb_online SET online_updated= '1777606581', online_forum = '23', online_topic = '11524' WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000169 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000748 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('40.77.167.155','51.195.244.127','51.89.129.242','51.195.244.110','185.191.171.2','202.8.42.144','66.249.74.100','54.38.147.200','216.73.217.23','66.249.66.68','66.249.66.70','66.249.66.69','185.191.171.17','198.244.183.209','198.244.226.86','51.195.183.102','198.244.226.15','198.244.242.189','185.191.171.12','177.12.16.152','51.195.215.194','66.249.66.194','185.191.171.8','198.244.168.165','85.208.96.209','198.244.226.122','198.244.242.233','51.195.244.24','85.208.96.193','85.208.96.202','198.244.240.224','198.244.168.188','198.244.168.201','51.89.129.68','51.195.215.50','202.8.43.51','66.249.66.72','198.244.226.249','185.191.171.19','85.208.96.210','185.191.171.13','85.208.96.200','66.249.66.7','85.208.96.198','198.244.168.35','185.191.171.16','198.244.168.99','51.89.129.16','66.249.66.6','54.38.147.178','54.38.147.102','51.195.183.233','51.195.215.109','51.195.183.72','66.249.66.71','198.244.240.37','66.249.66.43','201.182.169.97','85.208.96.205','198.244.240.45','198.244.242.0','85.208.96.194','85.208.96.206','51.195.215.91','54.38.147.222','66.249.66.74','66.249.66.166','51.195.244.254','66.249.66.193','66.249.66.73','66.249.66.164','198.244.226.211','198.244.242.249','51.195.215.231','198.244.183.46','185.191.171.3') )
0.000128 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '11524'
0.000230 - SELECT * FROM bb_online WHERE (online_topic = '11524' AND online_uid <> '0')
0.000084 - SELECT * FROM `users` WHERE uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000281 - SELECT * FROM bb_online WHERE online_uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000070 - SELECT groupid FROM groups_users_link WHERE uid=4151
0.000089 - SELECT groupid FROM groups_users_link WHERE uid=4050
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=1779
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=3663
0.000092 - SELECT groupid FROM groups_users_link WHERE uid=3841
0.000065 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000031 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000084 - SELECT groupid FROM groups_users_link WHERE uid=2683
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000023 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000023 - SELECT groupid FROM groups_users_link WHERE uid=888
0.000018 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000127 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000028 - SELECT post_id FROM bb_posts WHERE topic_id = 11524 AND pid = 0
Total: 67
Usage de la mémoire: 10234464 bytes
XOOPS a mis 0.209 seconde(s) pour charger
