88 Personne(s) en ligne (86 Personne(s) connectée(s) sur Forum)
Invité(s): 88
Fait toi aider.Et fait l'eux.
Kew-Kedew a écrit:
De Saumur 49 Maine et Loire
Post(s): 470
Mégane Coupé Ph2 1.6 16V RSI
du pédalier
sinon voila quelle que photos
De Nantes (44)
Post(s): 1123
Arff la jante a bien plié :-o
un becquet?
mikl68 a écrit:
un becquet?
sa je les dejas
Post(s): 1386
Post(s): 1175
Ah oui #censuré#!
Post(s): 1175
Post(s): 1175
j'espere bien pas cartonné
0.000143 - SET NAMES 'utf8'
0.001111 - SELECT sess_data, sess_ip FROM session WHERE sess_id = '0549edf858113aa2e9bff9848536998b'
0.000787 - SELECT t.* FROM bb_topics t, bb_posts p WHERE t.topic_id = p.topic_id AND p.post_id = 239954
0.000050 - SELECT * FROM group_permission WHERE (gperm_modid = '5' AND gperm_groupid IN (3) AND gperm_itemid = '23' AND gperm_name IN ('forum_can_post','forum_can_view','forum_can_reply','forum_can_edit','forum_can_delete','forum_can_addpoll','forum_can_vote','forum_can_attach','forum_can_noapprove'))
0.000361 - SELECT t.topic_id, t.topic_title, t.topic_poster, t.topic_status, t.topic_subject, t.topic_sticky, t.topic_digest, t.digest_time, t.topic_time, t.topic_last_post_id, t.approved, t.poster_name, t.rating, t.votes, t.topic_haspoll, t.poll_id, f.forum_id, f.forum_name, f.allow_html, f.allow_sig, f.hot_threshold, f.forum_type, f.allow_attachments, f.attach_maxkb, f.attach_ext, f.allow_polls, f.parent_forum FROM bb_topics t LEFT JOIN bb_forums f ON f.forum_id = t.forum_id WHERE t.topic_id = 11524
0.000840 - SELECT * FROM bb_topics WHERE topic_id=11524
0.000032 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=11524 AND approved = 1
0.001344 - SELECT COUNT(*) FROM bb_posts WHERE topic_id=11524 AND approved = 1 AND post_id < 239954
0.000056 - SELECT p.*, t.* FROM bb_posts p, bb_posts_text t WHERE p.topic_id=11524 AND p.post_id = t.post_id AND approved = 1 ORDER BY p.post_id ASC LIMIT 330, 30
0.000087 - SELECT * FROM group_permission WHERE (gperm_name = 'module_read' AND gperm_modid = '1' AND gperm_groupid = '3')
0.000231 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000382 - UPDATE online SET online_updated=1777606398, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000190 - SELECT * FROM online
0.000190 - SELECT COUNT(*) FROM online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000909 - UPDATE online SET online_updated=1777606398, online_module = 5 WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000145 - SELECT COUNT(*) FROM bb_online WHERE online_uid=0 AND online_ip='216.73.217.23'
0.000920 - UPDATE bb_online SET online_updated= '1777606398', online_forum = '23', online_topic = '11524' WHERE online_uid = 0 AND online_ip='216.73.217.23'
0.000152 - SELECT online_uid, online_ip FROM online WHERE online_module = 5
0.000796 - DELETE FROM bb_online WHERE ( online_uid NOT IN (0) ) OR ( online_uid = 0 AND online_ip NOT IN ('66.249.74.103','51.195.183.22','54.38.147.233','185.191.171.2','198.244.183.179','66.249.74.100','54.38.147.200','216.73.217.23','66.249.66.68','66.249.66.70','66.249.66.69','185.191.171.17','198.244.183.209','198.244.226.150','51.195.215.85','185.191.171.18','51.195.244.176','198.244.240.210','51.195.244.187','51.89.129.115','51.195.183.16','198.244.226.79','66.249.66.194','198.244.242.142','54.38.147.45','85.208.96.209','198.244.226.122','198.244.240.232','85.208.96.201','85.208.96.193','54.38.147.6','85.208.96.202','198.244.240.224','198.244.183.94','51.195.215.50','202.8.43.51','66.249.66.192','66.249.66.72','185.191.171.19','198.244.226.95','85.208.96.210','51.195.244.123','66.249.66.8','185.191.171.13','66.249.66.36','198.244.240.171','66.249.66.7','198.244.240.179','185.191.171.16','198.244.168.99','51.89.129.16','198.244.242.187','54.38.147.102','180.75.237.92','198.244.168.95','51.195.183.215','51.195.215.109','198.244.183.232','66.249.66.71','198.244.226.1','198.244.183.99','198.244.242.122','85.208.96.208','51.89.129.254','198.244.168.11','51.195.183.193','51.195.244.68','51.195.183.226','185.191.171.7','66.249.76.228','40.77.167.74','51.195.183.65','66.249.66.74','66.249.66.166','198.244.242.216','66.249.66.35','66.249.66.193','66.249.66.73','51.89.129.146','198.244.240.192','66.249.66.165','85.208.96.196','51.195.215.231','51.195.183.17','198.244.183.46','198.244.183.172') )
0.000125 - SELECT COUNT(*) FROM bb_online WHERE online_topic = '11524'
0.000144 - SELECT * FROM bb_online WHERE (online_topic = '11524' AND online_uid <> '0')
0.000103 - SELECT * FROM `users` WHERE uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000430 - SELECT * FROM bb_online WHERE online_uid IN (4282,3711,4151,4050,1779,3663,3841,1129,2683,3784,888)
0.000478 - SELECT groupid FROM groups_users_link WHERE uid=4282
0.000046 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000041 - SELECT groupid FROM groups_users_link WHERE uid=3711
0.000067 - SELECT groupid FROM groups_users_link WHERE uid=4151
0.000032 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 10
0.000046 - SELECT groupid FROM groups_users_link WHERE uid=3663
0.000089 - SELECT groupid FROM groups_users_link WHERE uid=3841
0.000032 - SELECT groupid FROM groups_users_link WHERE uid=1129
0.000025 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1386 AND rank_max >= 1386 AND rank_special = 0
0.000064 - SELECT groupid FROM groups_users_link WHERE uid=2683
0.000033 - SELECT groupid FROM groups_users_link WHERE uid=3784
0.000021 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_min <= 1175 AND rank_max >= 1175 AND rank_special = 0
0.000024 - SELECT groupid FROM groups_users_link WHERE uid=888
0.000243 - SELECT rank_title AS title, rank_image AS image FROM ranks WHERE rank_id = 12
0.000093 - SELECT * FROM bb_categories WHERE cat_id = 8
0.000023 - SELECT post_id FROM bb_posts WHERE topic_id = 11524 AND pid = 0
Total: 66
Usage de la mémoire: 10234288 bytes
